Old 26-01-09, 05:34 PM   #11
branny
Default Re: Dust AND piston seals?
leaving the seals in situe? I pulled out the seals and cleaned around in their slot.
Old 26-01-09, 06:39 PM   #12
branny
So this thread really gave me a complex! I rode home and checked the brakes out. I inspected all around the pads and there was no trace of fluid, BUT i squeezed the lever as hard as i could and i could hear a feint noise coming from the caliper. No fluid that i could see... but it may have sounded like a leak. I kept doing it and thought maybe the seals would make a bit of a noise when the brake activates.
Is the noise likely to be a leak? Or will seals make a noise when the piston moves?
Old 26-01-09, 06:51 PM   #13
arcdef
i had a leak in mine and it only happened when the brakes were used and only noticed because of the sounds you describe followed by a drip, turned out to be a dodgy seal, you may have seen my thread about it.
Old 26-01-09, 07:00 PM   #14
branny
probably about time i bought a seal kit then.... crap. did you ride the bike with the leak? I don't see it as dangerous, but it does seem a bit.... silly?
Old 26-01-09, 07:22 PM   #15
arcdef
no i noticed it whilst i was bleeding them which is lucky!! But yeah it only seemed to leak when i pushed the pedal in.
Old 26-01-09, 11:49 PM   #16
If in doubt remove the pads and check around the seal for traces of fluid.
However whatever haynes says, removing the pistons does not = new seals required.
Old 26-01-09, 11:56 PM   #17
husky03
seems to be lots of q's about replacing seals but as YC says not always needed but if you decide to-
http://cgi.ebay.co.uk/Suzuki-SV-650-...2em118Q2el1247
husky
Old 27-01-09, 08:06 AM   #18
branny
it is too late... i went on wemoto and ordered 4 of the piston/seal kits, rubber grease and some fluid.
I am going to do the whole job again on saturday!
Where brakes are concerned.. it just doesn't seem worth it.
Also, i neglected to tell you all that all 4 pistons were missing their dust seals. I should probably get some of them anyway!
Further to this, there were no squeal plates on any of the pads... this may have been my fault as i replaced the pads last time. But my brakes don't squeal anyway, so i am not worried about that.
Front calipers: no dust seals tubbycyclist Bikes - Talk & Issues 14 02-01-09 03:14 PM
Brakes - Dust seals removed. Grinch SV Talk, Tuning & Tweaking 7 19-02-07 04:20 PM
Dust Seals TSM Bikes - Talk & Issues 5 01-09-06 10:10 AM
Brake Dust Seals leegriffiths128 SV Talk, Tuning & Tweaking 2 16-12-05 06:59 PM
Caliper piston seals normas_glasses SV Talk, Tuning & Tweaking 1 31-01-05 08:04 AM
