Old 31-03-09, 03:34 PM   #11
panosm
Default Re: Top speed...not very speedy....
Originally Posted by Scoobs View Post
Depends on whether it is a carb'd bike or fuel injected. Carbs are generally restricted with washers whereas FI bikes have a restricted ECU.
Not sure if a Y plate is curvy or pointy?
i believe it is carb'd. Any ideas on where to go to get it destricted around portsmouth area?i need to find a decent mechanic......
Old 31-03-09, 03:35 PM   #12
plowsie
Curvey was up to 52 mateyboy
Old 31-03-09, 03:46 PM   #13
JamesMio
That sounds very much like my missus' bike (33bhp restricted curvy).
At 7k rpm an unrestricted bike should really be kicking into it's power band, if it's gasping a bit at that point it's very probably got a restriction kit in it. Not a big job to change it, my local garage installed the restriction kit in an hour, so I'd imagine it'd be the same in reverse?
"That **** on the push-bike."
Creatomatic
Old 31-03-09, 03:48 PM   #14
johnnyrod
johnnyrod's Avatar
If it's not restricted then it could be the under-tank foam gremlin
Old 31-03-09, 03:50 PM   #15
Scoobs
There is a little bike garage in Farlington (near Sainsburys) which I have used in the past and they are pretty good. Can't for the life of me remember what the name of the place is though.
They could remove the washers for you or maybe PM Grinch (he lives in Cosham). He has his carbs on and off all the time. He may be able to give you some pointers.
Old 31-03-09, 03:50 PM   #16
panosm
Hi James, i m going to have to look into it at some point during the weekend as i m working like hell as of tomorrow. This is exactly what happens with mine,pulls fine revs fine come top gear aroud 7k and thats it....no more power...insert coins to continue..lol
Old 31-03-09, 03:51 PM   #17
panosm
Thank you very much mate.
I send him a pm now.
Old 31-03-09, 03:56 PM   #18
Easy enough to check.
Remove airbox, open the throttle all the way, lift the carb slide up with your finger. Shine a light and can you see a washer in the way, or all the way down into the inlet tracts?
If no washer, then remove the rear pot carb slider (remove the black plastic carb top), does the slider have a horizontal hole in it?
1 is the FI international kit. Simply pull carbs and remove washers.
2 is the suzuki 33bhp kit, you need to find some full power carb slides without the hole in them.
Old 01-04-09, 01:17 AM   #19
Stig
My curvy is an 03
Old 01-04-09, 05:47 AM   #20
plowsie
Originally Posted by BigApe View Post
My curvy is an 03
Your weird then must be one of the last.
Panosm, you'll love it de-restricted mate
Woo hoo for Speedy Claire Shellywoozle The Border Patrol 3 17-12-08 11:44 PM
Speedy and Lucky go south! Luckypants EuroTour 58 28-10-08 11:35 PM
oi! Speedy! BabyJ Idle Banter 2 17-06-06 04:28 PM
Public Thankyou to Speedy: MrMessy Idle Banter 6 07-06-06 10:13 PM
Speedy response Beenz Idle Banter 9 05-05-06 03:00 PM
