Old 13-04-09, 08:38 PM   #11
cammy
Default Re: Hole in intake rubber?
Looked on parts drawings but dont see the tube coming of the rubber boot as a separate item, do you know if you can buy it or will it be that i have to buy the whole thing with the take off on it
Old 13-04-09, 08:39 PM   #12
Just the intake rubber. I've got some spares here...
Old 13-04-09, 09:14 PM   #13
cammy
I will try to put photo on to see if we are looking at the same thing the rubber looks joined onto the metal fixing plate
Old 14-04-09, 06:01 PM   #14
cammy
Rear rubber boot its a shame having to change it for not having take off on it, but i suppose if it all comes as one item i'l have to do that.
Old 16-04-09, 09:08 PM   #15
cammy
Has anybody else had the tube come off is it a push in fit or is it glued
Old 16-04-09, 09:10 PM   #16
Can't see a hole in that pic, am I being blind or is the hole just a little further around to the left than you can see?
Old 16-04-09, 09:50 PM   #17
cammy
yes its just round a bit i did not think the photo would come out so good i could have taken another just wondering how tube fixes as i could make something up or is it not worth it are they cheap to buy
Old 16-04-09, 09:53 PM   #18
If you want to fix it then look at fuel pump ... the vacuum hose needs connection to there. Find a bit of tube that will fit it snugly and epoxy/RTV it into the carb rubber. Only needs to seal. (you won't be taking the fuel pump off much once engine is in)
Old 16-04-09, 10:10 PM   #19
cammy
Thanks its a good nick rubber shame to bin it i will give it a go if you see someone stop in the middle of the road you will know it did not work
Old 16-04-09, 10:11 PM   #20
I've got spares if needed.
WANTED: SV1000 Snorkel / Intake pipe The Guru Stuff Wanted 3 19-05-09 07:47 AM
Air intake question John 675 SV Talk, Tuning & Tweaking 9 08-01-08 12:20 AM
Curvey intake valves and some collets svrash Stuff Wanted 2 30-01-07 09:48 PM
intake cams SV650 K3> r4ce_e3nd Stuff Wanted 3 29-05-06 10:08 PM
Air Intake! InvisableGeek SV Talk, Tuning & Tweaking 25 31-03-05 06:35 PM
