Old 19-04-09, 10:58 AM   #11
Default Re: exhaust leaking help
My exhaust blows has been for a while but its ignored and it passes MOT. Its got old goo stuff on it now, so needs resealing. Its ok for a while at least.
If you do get it anywhere else other than the join, leave it to dry and then attack it carefully with wet and dry. It will come off
Old 19-04-09, 11:17 AM   #12
If the end can is a bit loose on the headers, use a piece of an aluminium can as a shim, then clamp it up.
Better than that exhaust gum carp
Old 19-04-09, 11:20 AM   #13
pinman
well the stuffs on now. do i leave it a while or run the engine now(no thrashing). think this stuff sets harder the hotter it gets dosen't it?
Old 19-04-09, 11:26 AM   #14
What does it say on the tin?
Old 19-04-09, 11:29 AM   #15
pinman
lol. just read the back of it and it says exactly that.
Old 19-04-09, 12:13 PM   #16
mattSV
mattSV's Avatar
That exhaust paste is a complete and utter ******* to get off again.
I've not tried it but I know a few who have, get some builders silicone sealant and spread some of that over the joints and then it'll seal it up nicely. Plus its easy to remove again and it doesnt make a mess like the exhaust paste does that you've bought.
I have always used cheap as chips B&Q clear silicone sealent - job jobbed.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 19-04-09, 12:34 PM   #17
pinman
all done now but whilst doing it i noticed the clamps are abit corroded and past there best so when i get round to replacing them i may use sealant. that was a pain using that gum. i could really do with replacing the other exhaust clamp!!! yuck
Old 19-04-09, 10:07 PM   #18
lazymanc
That's what mine looked like, I just ordered a couple of stainless ones off ebay. I think one is 50mm and the other is 60mm.
lazymanc is offline   Reply With Quote
Leaking - What - Where? punyXpress SV Talk, Tuning & Tweaking 1 01-03-09 05:46 PM
fuel leaking out gas cap David Crosby Bikes - Talk & Issues 1 01-04-06 09:45 AM
leaking pipe... valleyboy SV Talk, Tuning & Tweaking 13 15-01-05 05:03 PM
Leaking Radiator Valman SV Talk, Tuning & Tweaking 16 02-01-05 08:34 PM
My '03 SV650S is Leaking Oil (HELP) nineteeneighty SV Talk, Tuning & Tweaking 3 28-10-04 11:36 PM
