Old 20-10-09, 07:48 AM   #11
MGessey
Default Re: Lost 6th Gear
Clutch is good, gear shift is good, changing from Neutral to 1st through to 5th is smooth & not sticky. The change to 6 is not like a false neutral, it does set itself with a smooth click on toe up, but on releasing the clutch there is no engagement, clutchless change has the same effect. Had a small 5mph off when the bike was 1 week old, so I have learnt how to ride properly, otherwise spotless & has been solid for 7 years now. Does this help?
Old 20-10-09, 07:53 AM   #12
jambo
jambo's Avatar
As Spannerman says, disconnect the gear lever and try selecting up to 6th using some mole grips or similar on the gear selector shaft.
If you can make 6th like that in the garage, then strip & clean the gear lever pivot, if you still only have 1st-5th then I'm afraid I stand by my previous suggestion.
Jambo
Old 20-10-09, 12:38 PM   #13
Leave the arm on the selector shaft or hold it in a rag before you put mole grips on it.
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
Lost 1st gear snoopy SV Talk, Tuning & Tweaking 104 07-01-05 05:57 PM
