Old 31-10-09, 04:21 PM   #11
tonny006
Default Re: Radiatior fan not working.
If i was you i would run it up a bit hotter as it won't boil untill it gets to about 130 degrees.
If it does need a switch,I have just checked and i have got one and you can have it free if you want to pick it up.
Tony
Old 31-10-09, 04:24 PM   #12
LK-SV
Nice one ..... obviously I'll give you some beer tokens for it ....
The next time I'm out I'll run it hot, and see what happens ....
Old 31-10-09, 05:59 PM   #13
bris
Mine kicks in at 100 or it does now anyway as it was'nt working. Got that part you need from ebay for a fiver and all is working. Mind you did'nt need it for over a year but only changed it after I was told it was'nt working by the garaage or would'nt have been any the wiser.
Old 31-10-09, 07:08 PM   #14
petevtwin650
Originally Posted by LK-SV View Post
I've got no idea what they cost !!
Price for an 08 model one
Old 02-11-09, 03:37 PM   #15
LK-SV
With a bit of luck, the used switch that Tony is kindly letting me take from him works ok……. So, whats the easiest way to drain, and then fill and in particular bleed the system again ??
TIA
Old 02-11-09, 04:15 PM   #16
petevtwin650
Old 02-11-09, 04:32 PM   #17
LK-SV
Nice one ... thanks ...
So, (sorry probably basic questions)
Can I just connect it, and drop it in a mug of hot water to purely test it works ??
Do I run the bike for a while without the radiator cap (or filler cap?) for a while to bleed it ??
Old 02-11-09, 04:38 PM   #18
Noble Ox
We have fans!?!?!! This is worrying as mines never come on! How do you test its working?
Old 02-11-09, 04:40 PM   #19
LK-SV
Run the bike until 100 degs or so .... should kick in ...
if not you're back where I was ...
Old 02-11-09, 04:41 PM   #20
Noble Ox
Its hit over 100 lots before. Is it noticable?
While you lot were working.... missyburd Photos 32 13-06-09 08:01 AM
Key not working wilky007 SV Talk, Tuning & Tweaking 12 29-12-08 01:27 PM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
not working Again! wtdafk SV Talk, Tuning & Tweaking 18 10-01-07 05:29 PM
Working on the SV william t. SV Talk, Tuning & Tweaking 12 04-09-06 10:23 PM
