Old 05-01-10, 09:11 PM   #11
Default Re: Rear wheel Break Light 'On' Position
Originally Posted by Damian View Post
yes thats what happened to mine i fix it the other week, dont for get the nut part dose not move,,,
Type in normal text you pillock.
If you turn the switch rather than the nut then you'll rip the wires out of one end or the other, reason I said to move the nut is because that's much easier than finding the connector and unplugging it so you can safely turn the sensor.
Old 05-01-10, 09:46 PM   #12
Stu
Trinity
Stu's Avatar
That's what suspected. I wasn't simply having a go at the newbie
any way mikebrooman good luck let us know it works
Is that after he potentially breaks his connector?
Old 05-01-10, 09:57 PM   #13
svdemon
Bend the spring a tad
Old 06-01-10, 07:11 PM   #14
Damian
Cool Re: Rear wheel Break Light 'On' Position
very nice pillock. ur good with words.it work for me the wire goes through like a brake cable dose. on my one
Old 06-01-10, 08:22 PM   #15
Big writing is just annoying, especially when you can't be arsed to type in English.
Old 06-01-10, 08:29 PM   #16
Damian
OK i cu ur point but next time ask nicely (arsed to type in English) if u mean my typing style, that 4me 2 do..
Old 06-01-10, 08:40 PM   #17
Right then;
Here's a switch.
See that square tab thing below the soldered joints? That holds the switch itself in place. It also stops the switch with it's pair of soldered wires from rotating with respect to the body of the part. This means if you spin the switch/sensor around, the wires spin too.
These are the contacts on top of the switch body. If you spin the sensor round and round repeatedly without unplugging the connector at the loom to relieve the strain on things, something will probably give. Either these or the crimps at the connector end.
This part:
Can spin around fine, because it's just a plunger which presses on the microswitch inside. But the wires on top can't. Though a few turns probably won't pull the solder joints apart.
And if that isn't clear then you can be excused the use of a spell-checker as you must have a crayon up your nose or something.
Old 06-01-10, 08:48 PM   #18
Damian
ok, ill make sure mine is ok then, nice pic`s
Rear break Light unpluged. mini_twin SV Talk, Tuning & Tweaking 3 07-08-09 05:34 AM
zx600r rear 'break' question, (rear brake). steve.s Bikes - Talk & Issues 6 19-02-09 07:50 PM
after market rear sets / rear break lights etuna SV Talk, Tuning & Tweaking 2 16-02-09 09:38 PM
Front break not lighting break light? Baz SV Talk, Tuning & Tweaking 18 14-07-08 11:52 AM
Break light, by which I mean it's broken, or do I? Perhaps I meant BRAKE. drag SV Talk, Tuning & Tweaking 7 23-08-07 11:22 PM
