#11 | |
My bike has standing battery of 12.5-13v, idle of like 12.4 and revs around 14v. I thought the idle voltage was wrong (as per this thread http://forums.sv650.org/showthread.php?t=144579 ) Soz for the derail matt; as said above those readings suggest the charging system ain't working (as said) it should be between 14 and 15v at 5k revs. I think the next step is to narrow down which component it is, luckily you have a curvy so the reg/rec's nice and accessible (remove ya rear pod plastics) you want to start the bike and disconnect the three plugs going into the regrec and put a multimeter (on ac IIRC) between 2 of the pins (then the next two then the next two so you've read the voltage between every terminal) and report back your readings. IIRC it needs to be 75v+ when revv'd
#12 |
I've taken the battery and charged it until the indcator light on the charger came up full, and then a bit more for good measure.
cleaned up the connector pins too and from the reg/rec but they werent that bad to begin with. Reconnected everything and taken some more readings, unsure of if the lights were meant to be switched on or not I did it twice either way. With lights off I get at idle a reading of 17.45V and at 6000 I get 17.79v at the battery. with lights on I get at idle a reading of 12.75 and 13.02 at some rev's (but dont know what the Revs were at). |
#13 |
Just seen your post YC, gonna check the yellow wires tomorrow night.
#14 | |
Follow YC's instructions ![]()
#15 |
As I said in text your reg rec has almost serpently dug its own brain out with a spoon.
#16 |
If the results in post No12 are accurate and reliable then this is almost certainly true.
#17 | |
As for the OP, yes, that sounds like the reg/rec's gone, and your battery will probably boil a bit if you keep running the bike ![]() |
#18 |
#19 | |
Hot grips cut out at idle but I can live with that.
#20 |
1 No. 2008 CBR600 RR Regulator Rectifier Ordered. Not too bad either, £40 plus postage
Complete Electrical Failure | kbh | SV Talk, Tuning & Tweaking | 34 | 07-08-11 05:38 PM |
Electrical failure. | AndyMcyD | SV Talk, Tuning & Tweaking | 10 | 08-06-09 04:45 PM |
Electrical failure | lookskyward1 | SV Talk, Tuning & Tweaking | 2 | 13-02-08 11:51 AM |
Complete Electrical Failure. | Grinch | SV Talk, Tuning & Tweaking | 11 | 12-03-07 05:27 PM |
Electrical System Failure | Torn-Thorax | SV Talk, Tuning & Tweaking | 3 | 01-08-06 10:07 PM |
