Old 27-05-09, 06:16 PM   #1
AndyMcyD
Default Electrical failure.
Right yesterday i started my bike as normal ride to work, but i noticed when i was on the A road my rev counter and speedometer was going crazy and my fuel light came on for 10 secs went of and kept doing it till i turned my bike off by work, then i turned it back on and it wont start, i bumpped it to get it home and noticed it wasnt going crazy no more,
ive checked the fuses
ill try and start it and nothing happend no noises or anything.
Can anyone help?
Old 27-05-09, 06:18 PM   #2
Default Re: Suzuki Sv 650 S 1999 Naked Verison. HELP
Loose connection somewhere probably, check the battery connections and starter relay area.
Old 27-05-09, 06:20 PM   #3
AndyMcyD
battery was lose, tightend it up
Old 27-05-09, 06:25 PM   #4
Is it still messing about or has that sorted it?
Old 27-05-09, 07:06 PM   #5
AndyMcyD
its still messing about
just wd40ed all teh connections front and back well up tillt he relay anyways
Old 28-05-09, 07:29 PM   #6
AndyMcyD
hey anyone?
Old 28-05-09, 07:29 PM   #7
Check the fuse holder in the starter relay
Old 28-05-09, 09:03 PM   #8
Biker Biggles
Biker Biggles's Avatar
Buy a cheap multimetre and check the charging system and battery as per Sid Squids post in the techy section.If that all checks out OK then look for chaffing in the wiring loom.Usual suspect points are around the headstock,under the seat where the seat bolts protrude into the loom,and under the rear cowling where the loom bends around the subframe.
Old 28-05-09, 09:23 PM   #9
svpilot
Hi mate,
Check the loom where it passes the headstock, my naked 99 developed a split in the sleeving here. Also the bolts that hold the side panels on can chafe the wiring too so may be a good place to check, good luck!
Laters,
Mark
*note to self - read all posts first! D'oh!*
Old 30-05-09, 02:30 PM   #10
AndyMcyD
hey guys look my alarm was at fault i got angrey and hammerd it todeath lol, soon to be running again
Complete Electrical Failure kbh SV Talk, Tuning & Tweaking 34 07-08-11 05:38 PM
MOT failure pinman Bikes - Talk & Issues 46 22-04-09 09:27 PM
Electrical failure lookskyward1 SV Talk, Tuning & Tweaking 2 13-02-08 11:51 AM
Complete Electrical Failure. Grinch SV Talk, Tuning & Tweaking 11 12-03-07 05:27 PM
Electrical System Failure Torn-Thorax SV Talk, Tuning & Tweaking 3 01-08-06 10:07 PM
