Old 07-02-10, 09:38 PM   #11
tanis34
Default Re: How to remove the front wheel without the bike falling over thread
this is how i did my front forks
Old 07-02-10, 09:41 PM   #12
fastdruid
fastdruid's Avatar
Here is me replacing head bearings, two axle stands under pegs, one pile of wood.
Druid
Old 07-02-10, 09:49 PM   #13
punyXpress
punyXpress's Avatar
Don't some pegs fold up?
Now: Street Triple R
Old 07-02-10, 11:29 PM   #14
pencil shavings
I never mentioned rafters?
yeah but others did, i think that way would be best, but cant do it.
oh now that is good! I might have to go that!!
Old 08-02-10, 12:08 AM   #15
-Ralph-
The engine has a hole at the front of the sump, directly below the oil level glass in this picture
Stick a steel bar through this hole and use an axle stand (or a pile of bricks, or a pile of books, etc) a each end of the bar, one each side.
Old 08-02-10, 12:38 AM   #16
fastdruid
fastdruid's Avatar
Yes, then you put the stands under the brackets rather than the pegs! Have to be a bit more careful.
Druid
Old 08-02-10, 12:46 AM   #17
-Ralph-
Druid
Pegs on my bike are too far back (pointy SV), if you put the footpeg brakets on stands the back wheel would be off the floor not the front. I guess the pile of wood is holding it up. Good way to get both wheels off the ground though.
Old 08-02-10, 01:09 AM   #18
i use a 10mm stainless steel rod inserted here:
then put up on a pair of axil stands. not a one man job though.
Old 08-02-10, 01:16 AM   #19
-Ralph-
It can be done on your own. Put the bike on the sidestand and jack up the right hand side far enough to get the axle stand under the bar on the right. Let the jack down and the bike will be supported by the axle stand on the right, the rear wheel and the sidestand on the left with the bike leaning heavily to the left and the front wheel in the air. Now jack the left side of the bike up until it is upright and level again and place the other axle stand under the other end of the bar on the left. Take the jack away.
Can you tell my wife would have a strop if I interupted her from whatever she was doing, to come out to the garage and help me?
Old 08-02-10, 01:18 AM   #20
fastdruid
fastdruid's Avatar
Doesn't even need a jack, just put the right side on the axle stand then push and lift the bike while sliding the stand under with your foot.
Druid
How do you remove the front wheel without a paddock stand? pointy SV Talk, Tuning & Tweaking 5 30-10-07 05:41 PM
the falling off thread :( kwak zzr Bikes - Talk & Issues 58 24-09-07 01:14 PM
How D'you remove wheel bearings... Stormspiel SV Talk, Tuning & Tweaking 9 22-11-05 09:21 PM
Humming sound from front of bike, wheel bearing? trailer_parks SV Talk, Tuning & Tweaking 7 09-12-04 01:30 PM
