#11 |
As per the 2 posts above.
I did fit a Lucas CAV (commercial) regulator to my BMW (bike) many many years ago, they were used by a certain car company in Crewe ![]() When I say worked*, it did until the crank vibration broke the field coil windings, and you had to re-wind the things. A common problem on both BMW and Guzzis. The R90S had a slightly lower alternator output than the other models, because the crank whipped a bit more so the rotor clearance was a bit greater inside the stator, hence less output. A nice feature on the CAV regulator was that there were 3 tapping terminals for the field connection which gave half volt increments in voltage according to your wishes. ... but I digress...
#12 |
#13 |
I have successfully used a blade R/R in the past. I guess the trick is to buy from a breaker of crash damaged etc. At least that way it was probably working upto the point it was taken off the road.
Not Grumpy, opinionated. |
#14 |
newer fireblades 08/09, the model number of the regulator must start with an F. Search previous recent threads, all the info is there.
#15 |
Or try svspares;
http://www.svspares.com/items/232-2_...fier-used-.htm However it is a used item, if it was me I would buy from there at least you know where to find them should it go wrong unlike ebay. |
rectifier/regulator | Ceebl | SV Talk, Tuning & Tweaking | 11 | 29-06-09 12:56 PM |
Regulator Rectifier | GeneticBubble | SV Talk, Tuning & Tweaking | 4 | 25-04-09 01:42 PM |
I need a Rectifier / Regulator. | Marv | Stuff Wanted | 3 | 19-08-08 12:43 PM |
Regulator/Rectifier? | Biker Biggles | SV Talk, Tuning & Tweaking | 22 | 31-05-07 08:55 PM |
Regulator/Rectifier | Steve T | SV Talk, Tuning & Tweaking | 3 | 10-10-04 10:34 PM |
