#11 |
I phoned J&S Accessories today (my nearest Yam dealer) and they could not check the price or order anything in because it was bank holiday, and they are now closed until Wednesday. I'll phone another dealer in Tamworth tomorrow, I don't like the idea of asking an acessories shop for mechanical parts anyway, at least with a dealer with a workshop you have some chance of getting the right part and the right advice.
TBH I don't like the OEM design and prefer a bolt, the threaded rod is a pain, you undo one and you get the nut off, you undo the next one and the rod turns with the nut and you get the whole thing, why not just use a bolt? Specialone, thanks, I'll call you at some point tomorrow. Last edited by -Ralph-; 03-05-10 at 10:05 PM. |
#12 |
Because a bolt moves with respect to the thread as you apply torque increasing risk of tearing metal. Especially with cheesium yammy alloy.
Stud, threads are stationary, you apply torque to nut so apply direct tensile force to metal of threads rather than combined tensile/surface traction (or frictional shear or whatever you want to call it)
#13 | |
OK so long as there is a good reason for the extra hassle, and given how little I trust my cheapo torque wrench (ok for 25nm, ok for 100nm, but at around 60nm I'm sure sometimes it just decides not to click and way overtightens) I'll get some OEM Yamaha ones ordered. |
#14 | |
My difficulty with finding a bolt is that the shoulder length tends to be too long, it has to be 12mm or less, or the bolt is going to stop turning before the sprocket is held on tight. |
#15 |
Are the threads right to the surface of the carrier?
#16 |
#17 |
Yes that sounds right. Not sure where you'd get those if local engineering place doesn't have them.
Maybe they would have studs with a plain shank in middle.
#18 |
I think ordering OEM studs from a dealer is going to be easier than trying to find a suitable bolt, and they must be fit for purpose.
#19 |
Yup. Some yammy spares are actually not bad prices. Bits for my RD400 were cheap enough
#20 | |
![]() 22 quid for the four studs, bolts and the lock tabs. They should be available to pick up on Friday. |
Which chain/sprocket and replacement bolts | Guy | SV Talk, Tuning & Tweaking | 13 | 11-08-09 07:55 AM |
Bolts for rear footbeg hangers??! | adamw2k2 | Stuff Wanted | 4 | 16-03-09 09:15 PM |
k3-k6 cush drive and sprocket bolts | drwracing | Stuff Wanted | 1 | 02-08-07 09:31 AM |
Sprocket cover bolts (pointy) | thor | SV Talk, Tuning & Tweaking | 6 | 19-11-06 05:29 PM |
Rear Sprocket Nuts And Bolts | sv182 | SV Talk, Tuning & Tweaking | 5 | 21-12-04 11:16 PM |
