#11 | |
If you go at it 10mins tops |
#12 |
Scottoiler, nuff said.
Really come into their own on a long trip IMHO.
#13 |
Take your most knackered boxers/Y-fronts/thongs on the trip. Once you've worn them. use them to wipe the crud off the chain and then bin them. As already suggested get a mate to pull the bike over onto the side-stand, lifting the rear wheel off the deck. I use a 'notched prop' under the right-hand paddock stand bobin when I do mine. It's quicker and easier than puting the bike on the paddock stand. Oh, and, any chain lube is better than no chain lube.
#14 | |
I don't see the point of lubing a chain when some nice man has designed a cheap and effective device that will do it for me. All I have to do is lift the chain now and then with my boot toe to check adjustment (7000 miles and only adjusted 1/6th turn of the bolt) and have a quick squint at the resevoir to see if there's plenty of oil left (Only topped up the touring kit once at 4500 miles) |
#15 | |
#16 |
Bout the same for me. I'll get a touring kit when I stop being tight. you get a REALLY clean chain if you forget to turn it back from prime when you fill it -bit expensive to run mind, it emptied the entire res in about 100 miles!
#17 |
Still easier than sitting there scrubbing with paraffin. Well worth the very low cost of the oil in my opinion
#18 |
What cost of oil?
#19 |
I have a 5 litre can of Husqvarna chainsaw oil that cost a tenner. I've had it for longer than I care to remember but it's coming to the end of the road now and I need to buy another. It's certainly been cheaper than original Scottoil at a fiver a 500ml bottle.
I won't use old bike engine oil for the same reason I won't put it in my engine. I know it'll only get thown off but there's something tells me it won't be as effective as fresh oil, and 5 litres for a tenner was a bargain so I didn't feel any real cost. |
#20 |
I agree that is cheap enough to not even factor into equation of running cost.
I think you might find it is more expensive now though!
Lubing Pivot Points | New Leaf | Bikes - Talk & Issues | 4 | 11-06-09 07:01 PM |
lubing cables | steveg | SV Talk, Tuning & Tweaking | 2 | 03-09-08 08:06 PM |
lubing the chain with engine running | crankcase | SV Talk, Tuning & Tweaking | 32 | 28-04-08 08:57 PM |
A noobie question about chain lubing | skyline | SV Talk, Tuning & Tweaking | 10 | 22-03-08 07:00 PM |
Chain Lubing. | yellowspanner | SV Talk, Tuning & Tweaking | 5 | 15-11-04 05:57 PM |
