Old 18-08-10, 08:27 PM   #11
Reeder
Default Re: Car Trouble
Just to make you feel better anyway about your impending cost that you couldn't have prevented...
Other day driving round some country roads, very slowly, barely any traffic and I see a hair on my steering wheel and try to flick it off, but keep missing. I completely lose concentration and drift to the left and smack the only raised curb in about 1 mile around on both my front and back wheels. £180 later and it's fixed... all for a hair on my steering wheel. Stupid idiot I am - completely avoidable!
Old 18-08-10, 08:32 PM   #12
ouch. That could have been worse. Are they alloys?
I'm not allowed alloys.
Old 18-08-10, 09:03 PM   #13
Kilted Ginger
SOunds pretty much like a wheel bearing, easy to check and cheap to repair.
Old 18-08-10, 09:12 PM   #14
rowdy
rowdy's Avatar
Wheel bearing can whine, rumble, or just fail. Easy enough to check, if it sounds like a front bearing leave the car out of gear with the handbrake on and get hold of the wheel and give it a damn good shake, if it sounds like a rear leave the handbrake off and the car in gear and give the wheel a good shake. If the bearing is knackered you will feel it knock on the hub.
Don't want to alarm you but I had a rear bearing go on a VW I had years ago. It decided that it would weld itself onto the hub while travelling down the road and snap the wheel and hub clean off!
Old 18-08-10, 09:21 PM   #15
Reeder
Only standard 2004 diesel corsa alloys
Both have hugeeeeee scrapes across them... but hey, I like the rough and ready look
Old 18-08-10, 10:24 PM   #16
Gordon72
could also be a brake caliper that has started to seize.
I have had it happen on two cars in the past.Easy to check,Take the wheel off and look at the brake pads,If one side is worn a lot more on one side of the disc then thats what it is.
Hours labour for the garage to give the pistons a clean.
It could also be any of the other problems metioned though!
Old 19-08-10, 08:09 AM   #17
dirtydog
Knob faced knobster
dirtydog's Avatar
I wish that was always true, needed both rear wheel bearings done on my mondeo for its MOT. Cant just buy the bearing had to buy the whole hub piece at £110 each side. The parts from Ford are over £200 each side
2011 Speed Triple 1050
Old 19-08-10, 08:56 AM   #18
Quedos
your wheel bearings have a tendancy to whine, more so, when you are going round corners or even slight knocking. So turn down the music and listen when you go round a roundabout and corners. Should be relatively easy and cheap to replace - I've done it enough times on the Polo
Old 19-08-10, 05:19 PM   #19
Car Trouble
Dirk wears white sox.
Old 19-08-10, 06:32 PM   #20
YouTube Video
Took the bike to work today. Meant to be rain tomorrow though so I'll take the car and maybe pop in to the garage on the way home, see what they think.
Trouble at 8,000 RPM leesh00 SV Talk, Tuning & Tweaking 15 20-07-09 05:09 PM
org trouble kwak zzr Idle Banter 5 22-06-09 07:45 PM
HID trouble. yorkie_chris SV Talk, Tuning & Tweaking 33 30-12-08 12:22 PM
car trouble rowdy Idle Banter 18 16-08-08 04:37 PM
In Trouble timwilky Idle Banter 28 29-05-07 01:52 PM
