Old 20-12-10, 07:13 PM   #11
barwel1992
Default Re: bearings - reconditioning
^ that what i thought but i suppose if quantity and quality of grease thats used in them is unknown its best to use ure own good quality and the right quantity of grease in them.
Old 20-12-10, 07:38 PM   #12
danf1234
Are they not sealed and full of grease anyway?
Old 20-12-10, 07:41 PM   #13
barwel1992
sealed - yes, full of grease - no idea lol
the ones i took apart were not "full" of grease more like a smear
but the ones i have ordered are higher quality ones than what was in there originally
Old 20-12-10, 07:46 PM   #14
danf1234
I put Kyoto bearings in my RSV and they were fine. Never even looked in them.
Or at least they were at 160 mph on my private runway!
Old 20-12-10, 07:48 PM   #15
Wheel bearings tend to have a separate seal too, rearset bearings catch a lot of crap.
TBH would you feel that slight notching in use barwell?
Old 20-12-10, 07:50 PM   #16
thefallenangel
don't over grease bearings. If they come sealed with a certain amount leave them like it. Slight amount of grease on the outside when fitting.
Old 20-12-10, 07:52 PM   #17
You can't over grease a rearset bearing. Pack the bugger until it's coming out of it's ears.
Any low speed bearing is same, they will squidge about a bit and be fine, wheel bearings or any other high speed bearings will be damaged by being fully packed so pack them 1/3rd or just leave them as they come from the manufacturer.
Wheel bearings are definitely one to buy KOYO bearings and not cheng sh*t pattern stuff.
Same as anything, right thing to do depends on application.
Old 20-12-10, 07:53 PM   #18
barwel1992
im not sure, it sticks as well and as its the gear side it could be whats causing my gears to slip out more and more in the last few moths and require more of a kick to get in to gear
well i have ordered them any way and see what happens, if the above problem gets better then at least it wont be a complete waste of money
head bearings coolbreeze Stuff Wanted 1 26-01-10 01:44 AM
Bearings Wideboy Bikes - Talk & Issues 6 08-12-09 09:18 PM
fork reconditioning Bibio Bikes - Talk & Issues 14 29-03-09 10:43 PM
bearings sv_rory SV Talk, Tuning & Tweaking 5 12-02-09 07:29 PM
Wheels and Bearings lawson17 SV Talk, Tuning & Tweaking 9 22-10-07 06:25 AM
