Old 16-01-11, 10:03 PM   #11
barwel1992
Default Re: re tapping exhaust lug
I know I said bolt above, but I prefer studs, stronger for same engagement and easier to remove if they are seized
i have already ordered some 45mm long bolts to cut down to studs and got some bras nuts coming as well
Old 16-01-11, 10:05 PM   #12
It is worth finding your local nut and bolt place, online can be very pricey for what for me is usually "ah give us 50p mate, be right"
Old 16-01-11, 10:13 PM   #13
barwel1992
yeh i agree i have looked before but not found any where that sells the sort of thing im usually after, i can get most steel stuf from college free but not SS as all the stuf they use are steel or NAS bolts
Old 17-01-11, 07:46 AM   #14
Spanner Man
Good morning all.
It is indeed an M8 x 1.25mm thread, & I would use a helicoil.
The down side with usung a cut down bolt as a stud is that, there's nothing to stop the 'stud' bottoming out in the hole. Whereas a proper exhaust stud has a plain section that stops the stud going deeper into the hole, thereby allowing you to tighten it before spinning the retaining nut on. Use some good quality copperslip on the stud & you'll have no trouble removing it should the need arise sometime in the future.
Cheers.
Spanner Man
Old 17-01-11, 07:58 AM   #15
Coming in slightly late
Ain't the curvy studs the correct size and pitch into the heads?
Tapping noise from engine. speedycoi SV Talk, Tuning & Tweaking 7 22-09-10 08:03 AM
Drilling + tapping swing arm pmapp SV Talk, Tuning & Tweaking 6 03-03-09 09:46 PM
Tapping noise yorkie_chris SV Talk, Tuning & Tweaking 6 17-06-07 01:44 AM
Engine Tapping Behind Clutch Torn-Thorax SV Talk, Tuning & Tweaking 22 09-01-07 12:48 AM
tapping when my bike got hot fullstop102 SV Talk, Tuning & Tweaking 6 30-07-06 10:39 AM
