#11 |
#12 |
I usuallly use a dremmell to clear out the gunk in the seal grooves but you have to be really carefull
#13 |
yeah i was, as usefull as wedging a screwdriver would be to clear the crap, I opted for a hair dressers pick thing, and was careful not to go too hard on it. was very good at getting the crap out from the edges, I could actually see grooves for the dust seal to go into when id finished!
#14 |
Right guys..... It seems that its leaking ever so slightly. So im going to have to pull them out again and try and see why. I did think that it was going to plan far too well.
There is very little if nothing more I can really clean off them, so im not entirely sure why this is. The pistons were not scored, the most violent thing I used on the fluid seal and inner bore of the piston was a toothbrush so I doubt I have damaged anything in there. If i take the seals out again, and cover them with red rubber grease, would this increase my chances of making a good seal? |
#15 |
Not sure it will improve the seal, but it's more advisable than using brake fluid on the seals, as that's what makes them go cruddy in the first place I believe.
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
brake caliper | mouldy | SV Talk, Tuning & Tweaking | 7 | 24-03-09 04:37 PM |
Quick brake caliper question | Needsy | SV Talk, Tuning & Tweaking | 8 | 18-03-08 08:38 PM |
Brake caliper help!! | Wee-Man | SV Talk, Tuning & Tweaking | 4 | 03-06-07 07:49 PM |
rear brake caliper question. | kwak zzr | SV Talk, Tuning & Tweaking | 10 | 08-05-06 10:35 PM |
