Old 06-02-11, 05:59 PM   #11
Default Re: ZX10R 06-07 Shock rebuild?
Yeah about 20 bar depending on shock
Old 06-02-11, 07:01 PM   #12
jambo
jambo's Avatar
I've had good service from companies like http://www.kais-ohlins.co.uk/ and http://www.k-tech.uk.com/ in rebuilding OEM shocks for my 2001 ZX6R
Jambo
Old 07-02-11, 09:35 AM   #13
mikerj
Sounds like an invitation to nitrogen embolism if you don't know what you are doing...
Old 07-02-11, 11:51 AM   #14
Not really, when filling it just attach filling tool and turn regulator, you are a good 2 foot away from the shock. I don't consider it too dangerous.
Discharging it perhaps but just point the valve away from you. The actual volume of gas is very small
Old 07-02-11, 12:06 PM   #15
mikerj
That's what I was thinking about, someone taking it apart without realising the amount of pressure in it!
Old 07-02-11, 01:38 PM   #16
CodeJACK
I'm "dying" to blow myself up!
Please tell me how? No seriously, I'm not a total fool and know about the dangers of working with nitrogen but as mentioned, I have a fella to drain and recharge for me.
Its the taking apart bit I want to know about in advance.
CodeJACK is offline   Reply With Quote
Old 07-02-11, 06:01 PM   #17
barwel1992
my college had a 40bar piggy back explode last year in the damper dyno, the dyno shroud was replaced but theres still a dent in the roof 15ft up in the air
Old 09-02-11, 03:50 AM   #18
HarryD
Regarding rebuilding a ZX10R shock, I found the following discussion on the SVRIDER forum.
http://forum.svrider.com/showthread....r+shock+manual
Old 10-02-11, 01:58 PM   #19
CodeJACK
Yeah, thanks, i saw that too but the manual in the link does not cover the 06-07 shock.
I'm not sure how to get at the bladder. i would also liek to know if its possible to modify it to allow for a valve? Read somewhere that someone was doing it but now cant find the link.
Think ill scrap this plan all together and just start saving for the full ZX10R
Old 10-02-11, 03:01 PM   #20
What, it has no valve? You sure it is not just a cap covering valve?
To get to bladder you release gas, push end cap in and remove circlip, then you can pull bladder out.
04/05 ZX10R shock andyb Stuff Wanted 1 17-05-08 07:46 PM
ZX10R shock neio79 SV Talk, Tuning & Tweaking 30 12-06-07 08:00 AM
zx10r shock weazelz SV Talk, Tuning & Tweaking 10 26-08-06 08:25 AM
'06 zx10r shock on '00 S curvy weazelz SV Talk, Tuning & Tweaking 1 17-07-06 03:14 PM
ZX10R K6 Shock andyaikido For Sale - SV's and SV related items 2 29-05-06 10:49 PM
