#11 |
They do indeed but my MOT guy hates them, the only bike that can legally run a HID is the new BMW K1600, which has one as standard.
#12 |
On the sv ive been running 100w bulbs for about 2 years (20,000 miles) and all seems well. The only thing ive noticed is the lense gets rather warm but hasnt tarnished/yellowed at all.
#13 |
HID's in cars are getting some attention from the Essex old bill .
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#14 | |
I wanted better light output, the current ones have a yellow hue and aren't that bright, I've seen folk change the lens and the bulbs but was just wondering if increasing the wattage (to something that has been proven on cars) would be a better option than spending ~15 notes on the nightbreakers etc...
Had an SV or three. Street triple R - gone but not forgotten. Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course. |
#15 | ||
Think I'll speak to Girth at the AR. as for HID's...no. Don't want to try and hide stuff on the naked bike, poorly adjusted HID's do my head in (there aren't any bike specific ones iirc) and it's still under warranty so I'm not doing too much to it yet. Just not my bag. Ste
#16 | |
Just don't throw in a cheap high wattage bulb and expect it to be better than the better standard bulbs, such as Nightbreakers of X-treme power. That is massive assumption, as many bikes come with lower wattage bulbs as standard (my curvy had 40/45w H4 IIRC) so the wiring is rated to that. Bike switches and wiring tend to lighter duty than cars so are more susceptible to being fried by high current. The alternator will also be sized accordingly, but I've not heard of problems in that area - although if you search on reg/rec you will find plenty of issues with these and running a higher wattage may cause it some grief, but I don't know what total load they are designed for.
"Your Viffer sounds like it is raising hell! Spot on." - Witchery 17/4/08 ![]() Snow Plough Appreciation Society - Member #3 ![]() Last edited by Luckypants; 05-08-11 at 08:37 AM. |
#17 | |
If you measure the volts and amps at the bulb they will not be running at 100W, the standard wireing is laughable... Factory Vs what I fitted. The insulation from the factory wireing was a loose fit inside the insulation for the new. ![]() Last edited by Stonesie; 06-08-11 at 10:38 PM. |
#18 |
aside from the already mentioned wiring/charging issues, high wattage bulbs
can burn out your reflectors too. you may gradually end up with worse lighting than you had with regular bulbs. |
#19 |
Cheers fella's, I think I'll go the nightbreaker route then.
I may still pop the 100W's in when it's dark just for curiosity's sake though and maybe take some photies. Ste
#20 |
You've got plastic lenses so any bulb envelope, irrespective of wattage, must be suitably UV shielded.
An SV can use standard 60/55W H4 bulbs without problems, if the wiring or switches suffer then there was already a problem with them. Don't waste money on HIDs, they will not be legal and most are crap anyway, I've already seen several that have failed, two where the driver unit has caught fire. Nightbreakers/Silverstars etc give more light with standard 60/55W current draw = best option.
Different wattage headlight bulbs? | Jamesy D | SV Talk, Tuning & Tweaking | 12 | 02-05-10 10:13 PM |
Higher bars on an N | aermacchi | SV Talk, Tuning & Tweaking | 1 | 07-07-08 05:11 PM |
higher watt bulbs. | BIKER-DENE | SV Talk, Tuning & Tweaking | 17 | 18-03-06 06:15 PM |
Higher bars. | BURNER | SV Talk, Tuning & Tweaking | 7 | 12-07-05 03:20 PM |
Headlight wattage - SV650S Y Import | sosh | SV Talk, Tuning & Tweaking | 0 | 11-04-05 12:34 PM |
