Old 02-10-11, 05:49 PM   #11
enzoalex
Default Re: Restricted SV shift points, and constantly changing temp
Don't you feel that the bike slows down the higher in the revs you go?
So it's faster to change gear earlier as you have more torque?
Old 02-10-11, 05:51 PM   #12
Felix_
Originally Posted by enzoalex View Post
It's a pointy. I just found that dyno map on google images.
I think the reason you're not getting past 8.5k in top is because the air resistance at that speed is equal to the force of the engine. Meaning you can't accelerate any more.
Whereas in the lower gears, you aren't travelling as fast, and so air resistance is less and you can keep accelerating past 8.5k.
Thinking about it that way, I think you may be correct lol. I've never really thought about air resistance before.
Oil Temp, Engine Temp and Rad Temp Owenski Bikes - Talk & Issues 0 30-06-11 09:36 AM
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Cooling fans constantly on stuartgallafant SV Talk, Tuning & Tweaking 7 12-10-09 03:50 PM
Shift-I Shift Light phizog SV Talk, Tuning & Tweaking 11 09-07-08 12:18 AM
Ideal Shift Points madEG SV Talk, Tuning & Tweaking 17 21-12-04 10:05 AM
