Old 13-03-12, 09:24 PM   #11
muzikill
muzikill's Avatar
Dont skoosh cleaner into the sidestand switch itll knacker it, prevent the circuit from closing and creating a fault. The seal on the pin that the stand pushes up allows dirt/dampness to ingress, the switch on the stand really is rubbish. Theres a way to test it in the manual to see if it will open/close. Until you get a replacement you can short it out at the connector under the tank that will allow the starter circuit to work.
FI light and no fuel pump whine ophic SV Talk, Tuning & Tweaking 13 06-09-18 03:50 PM
Fuel pump noise? gixer1 SV Talk, Tuning & Tweaking 0 07-01-12 01:06 PM
fuel pump continous hissing noise faztbikez SV Talk, Tuning & Tweaking 7 06-05-10 09:20 PM
No fuel pump noise when switching on ignition Swin SV Talk, Tuning & Tweaking 7 27-04-10 08:47 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
