Old 05-04-13, 12:32 PM   #11
nikon70
Default Re: Pillion peg spacer and bolt
that's an ugly piece of metal!
you might need to contact scorpion as this is a non standard size... so they might have had it fabricated for them....
this steel tube is known as DXH or XXH which comes in the following gauge:
3/4" (19mm) OD
which is wall thickness of .308" (7.7mm)
that allows the ID to be .434" (11mm)
or try and get it fabricated, or do it yourself, if you want send me a 20mm steel rod of the right length for your peg and I can drill a 8mm hole for you.
that's all I can find on Google....
Originally Posted by scottp_15 View Post
Unfortunately not, it needs to be 8mm internal diameter and 20mm external diameter. Been trying to find something for ages
Old 05-04-13, 01:20 PM   #12
scottp_15
3/4" (19mm) OD
I've called a few places for fabrication and the cheapest I have been quoted so far is £20, which seems a lot of money for such a small piece, or maybe I'm just being a cheap get.
I'd drill it myself but I don't have the hardware to do it. Thanks for the offer to drill it though. If I can get hold of a cheap cut of steel rod I'll take you up on that offer!
Thanks for the help so far.
Old 05-04-13, 01:22 PM   #13
What length is the spacer, I may have a solution
Old 05-04-13, 02:19 PM   #14
scottp_15
Spacer is 70mm in length.
Old 05-04-13, 05:14 PM   #15
We'll there a curvy engine spacer which has the diameter you're looking for, but it has a 12mm bore.
Plus its only 50mm long
You could get 2 & chop one down.
Maybe ask DavieSv or Yorkie Chris nicely and they might be able to machine a couple up for you for a lot less than the companies have quoted
Old 08-04-13, 03:59 PM   #16
scottp_15
Thanks for all the help. Got it sorted eventually. Had to pay Scorpion 30 quid to get all the parts sent, not so bad I guess
Old 08-04-13, 04:02 PM   #17
Oh well, its sorted now. Good O
Old 08-04-13, 06:15 PM   #18
adam_b
can you measure how long the tube needs to be reasonably accurately? and also the bolt? might be able to sort summat for ya in work on the lathe then ya see :P
Old 08-04-13, 06:19 PM   #19
adam_b
didnt see the second page on the bottom then haha :P sorry about that, glad u got it sorted
SV650S Barends, pillion peg bolts & infill bolt. phil24_7 Stuff Wanted 6 04-03-13 04:46 PM
sv650 k6 rear wheel disc spacer +bearing center spacer. jacknell Stuff Wanted 0 01-06-11 07:11 PM
Pillion peg mounting bolt size? Shaun. SV Talk, Tuning & Tweaking 2 31-03-11 07:08 PM
Lower Fairing Top bolt gromet and spacer DF! Stuff Wanted 2 20-09-08 05:06 PM
Bolt: Can / Pillion footrest MiniMac Stuff Wanted 2 01-05-08 07:23 AM
