Old 10-06-13, 11:40 AM   #11
dkid
Default Difficulty engaging neutral once warm
You can suck some out with a syringe and a bit of rubber tube from the filler hole.*
Edit* beaten to it
Old 10-06-13, 11:43 AM   #12
TamSV
TamSV's Avatar
Default Re: Difficulty engaging neutral once warm
Syringe works. If you don't have one then the easiest way is to crack the oil filter open a touch and let some oil drain out.
If you drain it into a clean container you can put some back in if you drain too much.
Don't bother trying to drain a bit out the sump plug. You'll drop the plug, 90% of your oil will fall out and the remaining 10% will run up your sleeve as you try to put the plug back in.
Old 10-06-13, 12:44 PM   #13
Steve_God
Have had the same issue myself - was topping it up after an oil change and overdid it by a tiny bit and that caused the gear shifting all round to be stiff, and making it really hard to get into neutral.
As the others have said, siphon out a bit of oil and it'll sort it
Old 10-06-13, 01:05 PM   #14
PyroUK
PyroUK's Avatar
That is what mine is doing!!
Almost exactly the same although oil not an issue as it has done it on low oil and normal level.
Jambo had a play at it briefly at last yrs AR which sorted it for a while.
Mine can go in to neutral on the move if I time everything right.
Mine has now also decided that if it isn't getting stuck in gear it shifts perfectly but will cut out when I pull the clutch lever (not great at junctions and roundabouts!!).
If you get yours sorted I would be very interested in how and see if it solves my problems! My L0 is currently at almost 19k
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 10-06-13, 08:29 PM   #15
Jason H
Jason H's Avatar
Cheers everyone for your input, syphoned off loads of oil (really surprised me how much) and now she's running really nice again.
Plus I also adjust ed the clutch again and fitted my CNC shorty levers this evening as they happened to have arrived today.
Naked K5 - Now Red with sexy stripes!!
Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock
Jason H is offline   Reply With Quote
Old 10-06-13, 08:37 PM   #16
DJ123
DJ123's Avatar
It's easy to drop oil out of the sump plug without losing all of it. Need to keep pressure applied to the plug blocking the hole and angle it to release some out. Then screw it back in.
BMW F800ST
Old 10-06-13, 08:40 PM   #17
Fallout
Fallout's Avatar
Just as a side note, too much oil is baaaaaad. Not sure exactly which seals it puts pressure on (maybe rings) but in any case, it starts squeezing through seals and causing damage. Never fill above F when the bike is upright. Sounds like you caught it early enough though.
I've overfilled before and just drain from the sump plug, but I like a good slippy fist.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 10-06-13, 10:10 PM   #18
Pete7
Pete7's Avatar
I have one of these on the boat for draining oil out of the engine. Brilliant bit of kit if you think you might be doing stuff regularly. The last one lasted 10 years being used with petrol, oil and sal****er.
Pete
http://www.force4.co.uk/859/Pela-600...ctor-Pump.html
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 10-06-13, 11:24 PM   #19
The Guru
Old 11-06-13, 06:28 AM   #20
timwilky
timwilky's Avatar
off on a tangent, love that the swear filter doesn't like sal****er.
Not Grumpy, opinionated.
Throttle play and difficulty finding neutral? zombie Bikes - Talk & Issues 10 07-06-13 01:44 PM
gears not engaging finchy001 SV Talk, Tuning & Tweaking 8 24-05-11 12:06 PM
Cant get neutral when bike is warm Tony Herbert SV Talk, Tuning & Tweaking 10 30-05-10 09:25 AM
Louder Noise when engaging first gear Ollie_07 SV Talk, Tuning & Tweaking 5 04-03-08 08:33 AM
Bike stalls when engaging first gear. SVChick SV Talk, Tuning & Tweaking 10 13-02-06 03:57 PM
