Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits. |
#11 |
The rubber boot which goes over the clutch lever covers the rivet end (i removed the large rivet head) I bought some for my wifes k3 model and they are fine, its a different micro switch on the earlier model
#12 |
Mine is a 2000 naked curvy
#13 |
Problem solved
![]() After a ride over to willingham woods on sunday i can confirm all is well. The simple mod has cured the stalling issue, why????? i do not know!!! |
#14 | |
I have the absolute same issue.... http://forums.sv650.org/showthread.php?t=217624 And to top this off, the bike shop charged me for a replacement STVA which didn't fix the problem. All this time and all it was, was the after market brake levers. Garysv1000, is there any chance you could post a pic of your modification, the pic is no longer showing. Cheers Roger Last edited by funkydruid; 31-05-15 at 04:15 AM. |
#15 |
I will take a piccy later for you mate and post it up if this helps
#16 |
![]() ![]() ![]() The first picture is from underneath the lever, the second is from the top, the rubber boot covers the mod up nicely ![]() Picture as requested Roger, sorry for delay Last edited by Gary1966; 22-06-15 at 03:57 PM. |
#17 |
update. the information i gave is wrong. it looks like suzuki have actually for once not done a parts bin special and the later SV clutch lever is indeed a one off specific to that perch.
tried and tested on an L0 (2010) with using a gsxr oem lever. it fits and works but rubs the cable on the adjuster. had more of a dig and official suzuki website states that bikes up to K9 (including curvy) use same lever and perch. bikes from L0 (2010) use different lever and perch which is same as weestrom (DL650) L0 Last edited by Bibio; 19-08-15 at 11:39 PM. |
#18 |
Well spotted
#19 |
I bought some Gladius Chevers. They work, but the fit isn't 'perfect'.
Shorty levers for 2010 sv650s | PyroUK | Stuff Wanted | 17 | 30-05-13 04:27 PM |
bypassing clutch switch and side stand on 2010 model? | cmjhs | SV Talk, Tuning & Tweaking | 7 | 19-10-11 09:09 AM |
Carlsberg rideout 2010... 16 MAY 2010 it is then ! | Paul the 6th | Pennine Massive | 80 | 19-04-10 09:38 AM |
Curvy Carbs, clutch levers and brake levers | 21QUEST | For Sale - SV's and SV related items | 2 | 03-03-10 11:04 AM |
After market levers (gsxr) | scottjames | Bikes - Talk & Issues | 3 | 16-10-09 11:31 PM |
