Old 14-06-05, 04:16 PM   #11
AlfBoy
Yes, the popping is a good thing!
My scorpion can causes a lot of popping when rolling off the throttle and on down shifts, but I like it that way, it sounds great!
Old 14-06-05, 05:46 PM   #12
sprocket
Yeah my viper does the same, sounds lovely especially when in a valleyish area so it echoes
Old 15-06-05, 07:45 AM   #13
Carl
So popping is ok then? well thats fine with me. Dont think there are any leaks, work collegue (also bike mechanic) had brief look and couldn't find a leak. So if I decide to add a filter is it worth it? Would I get away with just fitting it as is?
Old 15-06-05, 08:33 AM   #14
BillyC
BillyC's Avatar
Yeah, you'll get away with it... I have! When I changed my plugs a few weeks ago, it did suggest that the bike was running a bit rich (as does the mileage I'm getting now), but that's generally not too much of a problem.
The filter will ease up the running of the bike a bit, and you'll notice the difference at the top-end as well. However, if you've got both the filter and can fitted, the remap is something you should look to get sorted out.
Stage 1 ,3 ect jet kits....stage 2? Torn-Thorax SV Talk, Tuning & Tweaking 11 05-03-07 07:36 PM
who has JHS stage 2 or factory pro stage 2? 01 sv650s SV Talk, Tuning & Tweaking 1 15-12-06 08:12 PM
Stage 2 cams (again) - dynos! johnnyrod SV Talk, Tuning & Tweaking 26 23-07-06 12:56 AM
JHS stage II cams for $200 Ziguy SV Talk, Tuning & Tweaking 75 19-03-05 05:18 PM
JHS Stage 3 Forks! 454697819 SV Talk, Tuning & Tweaking 2 14-10-04 11:59 AM
