#11 |
urr - whats the relay bit mean ?
#12 | |
#13 | |
#14 |
I know that the standard horn location on my SV1000S K3 is directly between the rad and the engine, and its a common problem when the engine and rad get hot for the horn to stop working. I bet iyour horn worked fine once the bike had been left to cool down for half an hour or so.
I fitted a stebel magnum horn inside the right hand fairing (in front of the radiator cap). The steering damper clears it by 10mm. Nice and loud, and can't be seen as it is quite large comapred to the standard one. You don't need a relay to run the stebel magnum. |
#15 | |
Ok, makes sense.... yesterday was a very hot day and this morning the horn was back.
#16 |
just bought one
#17 | |
I've got one, fits ok, sound is deeper and louder. I think cheapest and easiest upgrade option. Mine was a direct fit, no relay needed on my curvey, about 2 months I've had it and use it for greeting a few dozy folk with great success ![]() |
#18 |
Connected it up to an ER5 at work this morning. It's way more impressive than the original horn but it's not as loud as I'd secretly hoped... that 136 db is at 4 inches from the horn outlet, so unless you can get the cabbie/ped/BMW driver to stick their ear that close...
The stebel website is at http://www.stebel.it/ for anyone interested in their horns... interesting to see that at 12V the horn pulls up to 6A, and although it's not mentioned on the packaging, it seems that the horn can be run at 24V as well. For £14 including the P&P from NippyNormans (and the fact that I ordered it at lunchtime on Friday and it arrived on Saturday morning), it's well worth it, and it's totally easy to fit - pull off spade connectors, unsrew existing horn, screw on new horn and reattach connectors. It's much lighter than I thought too - about 250g. |
#19 |
Bah! I tried to fit the magnum this morning - where's it meant to go!? There's no way it can fit in the gap that the original horn goes, behind the radiator! Plus the connectors don't match and will need cutting or replacing... poo! I'm thinking of attaching the magnum to the caphead screw on the frame on the left hand side and leaving the old horn there and fiddling witht he connectors, but then it'll look like a dogs dinner.
Stupid Stebel! |
#20 |
i tried fitting it to my CBR yesterday, just uplugged the old connectors and plug them into the new horn.
but to he honest, its bigger than my old horn and is about the same volume - just sounds a tiny bit more like an air horn, still more or less the same ![]() |
Ive Got the Horn | Blue Flame | SV Talk, Tuning & Tweaking | 33 | 27-05-08 04:01 PM |
Horn | ljharmitt | SV Talk, Tuning & Tweaking | 5 | 26-04-08 10:18 AM |
Where`s My Horn??? | Speedy Claire | SV Talk, Tuning & Tweaking | 33 | 21-01-08 12:18 AM |
Use of horn | Blue_SV650S | Bikes - Talk & Issues | 31 | 13-12-07 10:35 PM |
Get the horn | northwind | SV Talk, Tuning & Tweaking | 44 | 02-03-05 12:22 AM |
