Old 21-12-05, 04:43 PM   #11
Peter Henry
Randy...Come on he did not say he was going to do a service....just an oil change.
Leigh it is pretty important to take your time with the refilling with new oil, dont forget to run the bike for several minutes, turn off and wait again several minutes and check the level with the bike on a level surface to see if it has reduced following circulation of the oil around the motor and filter.
Old 21-12-05, 06:35 PM   #12
Stig
It's also handy to replace the sump plug BEFORE you add the new oil.
Old 21-12-05, 06:44 PM   #13
manxsv
Dont drop the container of old oil like I did, it makes a bit of a mess
Old 21-12-05, 06:57 PM   #14
mynameis
A proper filter wrench also makes the job alot easier, especially tightening the new filter correctly.
Old 21-12-05, 07:16 PM   #15
Biker Biggles
Biker Biggles's Avatar
After draining the oil into a suitable receptacle,and moving it carefully away from beneath the bike,avoid turning round and treading in it.
Ruined a perfectly good pair of shoes.
Old 21-12-05, 11:43 PM   #16
Best bit of un-necessary verbose advice so far.
Old 22-12-05, 03:18 AM   #17
Samurai
Thanks guy's will take it all in to consideration,
makes it so much easier when you have access to all this experience
Spend £117 & change on bike - but no change in bike pete m Bikes - Talk & Issues 10 06-05-09 12:26 PM
Just done an oil change! Kinvig SV Talk, Tuning & Tweaking 8 14-10-06 04:56 PM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
