#11 |
Rear brake of a pointy?
Front bolt - the larger one - 20 lb-ft. Rear bolt - the smaller one - 16.5 lb-ft. The front bolt is also one of the sliding pins of the brake, only use rubber grease on it - it passes through a rubber bellows which will be damged by any other sort of lubricant. Incidentally Suzuki specify a torque setting for the brake pad pin - 13 lb-ft - but I'd go easy with it, the pin and the caliper body are quite soft and easily damaged, as long as it's secure and the plug, (1.8lb-ft), is snugged against it, it will be fine.
#12 | |
Removing the rear wheel | gilby104 | SV Talk, Tuning & Tweaking | 20 | 26-09-08 08:27 PM |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
Removing rear fender | Jamie Slick | SV Talk, Tuning & Tweaking | 1 | 26-04-08 07:20 AM |
Rear Caliper | Bikerz | SV Talk, Tuning & Tweaking | 15 | 08-03-07 09:18 AM |
Removing rear fairing | elqueson | SV Talk, Tuning & Tweaking | 15 | 14-11-06 08:58 PM |
