Old 12-06-06, 05:24 PM   #11
i am a bit anal.. and would have to have it way way neat !!.
thats why I have deffered from one at the moment ....cos i dont think they can be neat-
looking fwd to seeing fizz's at the weekend.
or are you two up on ED's??
Old 12-06-06, 05:25 PM   #12
Kylie
Kylie's Avatar
This is how I fitted one to my K3. Its not particularly clever or aesthetically pleasing but it works and has been no trouble for the year I've had it. As ye can see I'm not too bothered about keeping that end of my bike super clean and tidy anyway.
The observant will spot that I was slightly cleverer in the siting of my starcom box.
I'm Mike. Kylie is an SK3 with OE lowers, R&G bungs, OE double bubble, Scottoiler, Starcomm, Hamicad tail tidy, bruised and in need of a wash.
Kylie is offline   Reply With Quote
Old 12-06-06, 06:08 PM   #13
andyaikido
Didn't your scottoiler come with a little tube of superglue? I stuck mine to the bottom of the swingarm with this and its been good for the last 6000 miles. No cable ties to help either, i'm a bit anal like that too.
Old 13-06-06, 09:23 AM   #14
petevtwin650
I used the superglue too. stuck my hand together as well, but that's me
I presume you cleaned and degreased the underneath of the swingarm first. I then used the supplied bracket that goes over the rear wheel spindle. Cut a slot in it and mounted inside the swingarm off the spindle. Looks neat and provides support for the delivery tube right onto the chain
And I think it does look pretty tidy. Just got to get the flow rate right now. The warm weather has made it flow more.
Old 13-06-06, 09:26 AM   #15
Grinch
be carefull as if you have a too clean smooth surface the supper glue my give up in time... I had some of mine come off though only one connection at a time. So keep a eye on it. I now have it cabled to the swing arm and glued to where it feeds back behind my triangle.
Fitting a Scottoiler delivery pipe. Lozzo SV Talk, Tuning & Tweaking 14 16-01-08 06:41 PM
curvy scottoiler mounting? hovis SV Talk, Tuning & Tweaking 7 20-06-07 01:16 PM
fuel tubing as replacement brake tubing? weazelz SV Talk, Tuning & Tweaking 8 24-03-07 04:26 PM
Pointy Scottoiler mounting tapemonkey SV Talk, Tuning & Tweaking 12 03-02-07 07:14 AM
Scottoiler Tubing issues MarkyBoy SV Talk, Tuning & Tweaking 7 08-08-05 02:22 PM
