Old 18-12-06, 10:28 PM   #11
Bear
Originally Posted by netsurfer
Easiest way to rule it out, try starting with the clutch out
Sorry, I'm a little confused. It won't start unless the clutch is pulled in anyway.
I've left it outside my local bike shop (coz I wasn't gonna push it straight past just to push it back in the morning!) so I'll try that tomorrow. Any other hints people?
Old 18-12-06, 10:31 PM   #12
fizzwheel
fizzwheel's Avatar
It wont, which side did it go down on maybe the clutch levers a little bent and even with the clutch pulled in its not working the bypass switch properly.
Might be worth having a search for the instructions on how to bypass the clutch switch and then see if it'll start.
Old 18-12-06, 10:35 PM   #13
Bear
No, I didn't actually drop it. It leant over a fair old way but i managed to manhandle it back upright.
Old 18-12-06, 10:36 PM   #14
mattSV
mattSV's Avatar
Or knocked it into gear trying to get it up?
Does it come up with CHECK on the dash?
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 18-12-06, 10:38 PM   #15
TSM
The Sick Man
TSM's Avatar
If the lights are dimming when you press the starter then everything with the starter circuit should be ok, just that the starter is not turning over.
When you try and start the bike, do you hear the starter relay clicking, when you turn on the bike with the Kill switched off, do you hear the injectors priming? Any error codes on the LCD (you will probably have to put it in "dealer mode")? Explain more this noise you herd from the engine before it went all wrong.
Even with the clutch pulled in or out a push start should be enough to turn over the engine bypassing the starter circuit.
Old 18-12-06, 10:38 PM   #16
fizzwheel
fizzwheel's Avatar
Liz's K5 did this when I dropped it with the motor running, We picked it back up and switched the ignition off I took the key out and then put the key back in and it started fine.
When you turn the ignition on can you hear it whirring as it pressurises the fuel rail before you go to start it ?
Old 18-12-06, 10:39 PM   #17
Bear
No, only thing on the dash is the oil light. it's not an in-gear issue, as I've push started it and had it running (And when it's running the oil light goes out)
Old 18-12-06, 10:40 PM   #18
Bear
Old 18-12-06, 10:40 PM   #19
Bear
Yep.
Old 18-12-06, 10:46 PM   #20
fizzwheel
fizzwheel's Avatar
Umh... weird...
So with the ignition on with the bike on the sidestand, you've got an oil light, you hear the bike pressurise the fuel rail and you've got a Neutral light, but when you pull the clutch in the lights dim, the starter doesnt turn and the headlights dim.
A sad start to the day ooger Idle Banter 17 03-06-08 11:27 AM
Bad start for the day timwilky Idle Banter 13 22-04-08 09:52 AM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
yet another won't start, 01 650 mann650 SV Talk, Tuning & Tweaking 4 25-07-06 03:54 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
