Old 18-04-07, 07:04 AM   #11
John 675
Default Re: False Neutral?
Mine's been getting stuck in the actual neutral quite a bit lately (changing up and down) even jumping out of second once. Has caused me to have a few close calls and even more embarrasment (Went to drag away from the lights to find it had stuck in neutral ).
Guess I'll check all the above points!
Yeah i know what you mean i have had that quite a bit normally giving the shift a bit more of a kick to make sure its in second works . shouldnt worry about it,
DOES ANYONE elses bike make a really nasty crunch sometimes when dropping in to first gear? because sometimes mine feels like it really grinds and the crunches, but only sometimes. anyone had that ?? ? ?
Old 18-04-07, 11:32 AM   #12
richbeales
About the crunch into 1st gear, yes mine does that more often than not, I try to roll the bike back and forth to get it to engage "nicely" without having to force it against its will.
I'm on a 650S K5 with 4500 miles on the clock. Oil is fresh.
Any other people or is it just the two of us?
Old 18-04-07, 11:45 AM   #13
2mths
650S K5 4750 on the clock (old oil).
No crunches here, but I don't push hard, if it doesn't want to go in, which I do get, with a light tap then I don't force it.
Instead I let the clutch out slightly, then pull it in again and then it drops in sweetly.
I think this a bit like double-declutching, or when you're trying to find a stubbon reverse in a car. When in neutral, letting the clutch you to spin the gearbox a bit then trying again seems to work better. I don't know what the mechanical reason for this is though
Old 18-04-07, 12:51 PM   #14
John 675
Post Re: False Neutral?
The funny thing is mine is a k5 with 5000 miles on it! ! ! maybe its a k5 thing??
Old 18-04-07, 06:18 PM   #15
phil24_7
No my K3 does it as well. Sometimes I release the clutch a little and sometimes I just force it (my girl likes it rough sometimes!).
My gear changes aren't the smoothest at the best of times tho!!!
Old 19-04-07, 08:22 AM   #16
petevtwin650
Personally I would be worried if I were having lots of false neutrals. On the Sv you do rely a lot on the engine braking, and the snappy acceleration. Wouldn't think it was the gearbox, rather the linkage (good tip from Northwind on that one), maybe clutch or rider error. Best to look at all 3 IMO.
Old 19-04-07, 08:47 AM   #17
svJvJ
I found this interesting reading......Kinda related to this thread
http://forums.sv650.org/showthread.p...45#post1164645
False neutral between 5th and 6th - be concerned? mattb200 SV Talk, Tuning & Tweaking 5 09-03-09 08:27 PM
False neutral light JediGoat Bikes - Talk & Issues 11 05-09-07 09:14 AM
False Neutrals? rob13 SV Talk, Tuning & Tweaking 18 03-09-07 12:10 PM
False Neutrals thepyrofish SV Talk, Tuning & Tweaking 13 17-07-06 12:20 PM
False neutrals Fuzz SV Talk, Tuning & Tweaking 18 23-08-05 11:46 PM
