Old 27-06-07, 08:20 PM   #11
Grinch
Default Re: Help, no rear spark... no AR
Well I'll be giving that a go tomorrow as long as the weather hopefully holds out.
So the conclusion at the moment is the signal generator or the loom. The signal gen I can swap but the loom is going to be hard as I have wired the alarm into it. So I will just have to pull the whole lot out and check it all.
Old 27-06-07, 11:51 PM   #12
Grinch
I would work my **** off and get the other SV working but I have only one bolt on the front exhaust, and it ain't coming out with out some serious graft. So at the moment it would never pass a MOT, as the last job was to trailer it up to a mate to mig a leaver on to the bolt to work it off. Unless anyone knows another trick?
There is about 10mm of bolt shaft clear from the front cylinder, I was thinking of getting the bike up to temp, spray with plus gas and then working at it with some mole grips.
Old 28-06-07, 06:33 AM   #13
dirtydog
Knob faced knobster
dirtydog's Avatar
I managed to get a completely knackered and snapped stud out using some mole grips
2011 Speed Triple 1050
Old 28-06-07, 07:47 AM   #14
Grinch
Cheers that's given me a little hope.
Old 28-06-07, 12:08 PM   #15
Grinch
Well its running, fired her up and both cylinders got hot. But then I notice oil seaping out, which I supect is where the gasget tore. To make it worse I tore the gasget on the other bike too, they just seemed to stick to the casing. In my frustration to get it sealed I have sheered the nut off, bugger.
So I'm going to have to drill that out, good job I have spares. Though I can't get a gasget till tomorrow as no one local has any gasgets in stock, so I'm going to have a busy morning tomorrow.
Once again a last minute rush to get it all done. It's putting a lot of dought in my mind about going now, as it seems like everything is set against me. I want to say stuff it and go and drink some beer at home and maybe go and watch Pirates of the Carabeian.
Old 28-06-07, 12:14 PM   #16
jambo
jambo's Avatar
You can make a decent gasket from a cornflakes packet or using instant gasket. You've come this far and made it work, seems a shame not to push to get the last thing done
Old 28-06-07, 12:17 PM   #17
join the club. matt sat in three hour exam at mo. he had probs with raptor. balanced throttle wotsits, changed spark caps..to no avail and then noticed..no gaskets. when he bought it they tried to put an exhaust system on that wouldn't go, so put back on the original system ..badly. So gasket on this aft and toes and fingers crossed it magically makes things better. pain in the ****. but at least theres suzy as back up..famous last words!!!
Old 28-06-07, 12:29 PM   #18
454697819
B&Q - black silicone sealant
as good as any gasket...
Old 28-06-07, 12:35 PM   #19
Grinch
Cornflakes! Well I've spoke to Sid and he said don't worry about it, just get some Hylomar Universal Blue and seal it best up. The bolts are there for to keep the casing on rather then keep sealed as there is no oil preasure.
Old 28-06-07, 01:25 PM   #20
jambo
jambo's Avatar
Cornflakes!
No Cereal packets in the Grinch household then... I suppose Hymo is the correct thing to use.....
Mk3 Golf, no spark... rubberduckofdeath Idle Banter 7 29-05-08 10:03 AM
No Spark yorkie_chris SV Talk, Tuning & Tweaking 27 15-09-07 05:29 PM
no spark hovis SV Talk, Tuning & Tweaking 10 27-06-07 03:19 PM
No spark...please help. leegriffiths128 SV Talk, Tuning & Tweaking 0 11-11-05 05:17 PM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
