Old 28-10-07, 04:24 PM   #11
Default Re: Is it possible to change tyres yourself?
My breaker was £19 off EBay, very simple but it works, just a big braced lever. I tried shovels, bits of wood etc but I weigh 9 stone so I needed a VERY long lever Plus, on one tyre I discovered I was lifting the set of brick-and-concrete steps I used to set the lever in, rather than shifting the tyre. That's no good...
I also picked up a No-Mar tyre bar, which is great, though pretty expensive. It makes it easy, I'm too feeble for normal levers but this thing reduces the risk of scraping the rim to about zero and it's quick, too. I'd say without any fear that I'm less likely to mark the wheels than any of the garages I've ever used, using this thing, there's absolutely no metal-on-metal contact.
The only reason I got the setup was because I was planning to use race take-offs for trackdays. And then shortly after, I decided to stop doing them But it's still nice to have- I got a puncture the day before the SV650.org end of year rideout, took the tyre off as soon as I got home, put on an old spare, rode and got a new one fitted (for free, if it'd been paid for I'd have done it myself), there's no way I could have sorted it out normally. And my last set of Sportecs cost me about £110, then I fitted 'em- the local dealers don't like fitting other people's tyres, so you pay more. I think the rig will pay for itself in another year, and then it's just about the time taken.
Old 28-10-07, 04:36 PM   #12
haggis
I put a set on after getting the wheels powdercoated.
I had polished rims before that and the fitters usually said 'Ooooh, we cant be certain not to mark them, so it's up to you. Shall we go ahead?' Typical, just covering their arses....
So this time i thought feckit, if I scratch em it's all my own fault.
First time i've done it. No big drama, all done in 40mins. I do have car biased levers tho, which helps get the last bit over the rim. Used a portable compressor after that.
I've not taken a set off yet, so breaking the bead might defeat me. I do know someone with a proper breaker I could borrow if need be.
Old 28-10-07, 07:42 PM   #13
chazzyb
SV: tyre place does it; I'm a coward.
All my other bikes with *tubed* tyres: I do it.
Washing-up liquid as lube? NO! Full of salts which may corrode your rims. I have a jar full of goo made from pure soap flakes (Dreft, all say aaah), disolved in water. I brush this on liberally where required.
Old 28-10-07, 08:18 PM   #14
pilot
Good video on how to change a tire...
http://video.google.com/videoplay?do...09776315225781
Old 28-10-07, 08:52 PM   #15
monkey
Nice. Well until you reach 7 minutes and 50 odd minutes when he turns the wheel round to see LOADS of paint chippping! He he he. Bet the music covered up a lot of cursing.
Think when the time is right I will give it a go. I have to practise on some old spoked wheels first anyway.
Old 28-10-07, 08:53 PM   #16
monkey
I've found wheel balance weights on fleabay at a very reasonable price too.
Old 28-10-07, 09:06 PM   #17
pilot
Don't forget to report back and tell us if it can be done as easily as shown in the video; inquiring minds want to know. That chap seems to be changing the tire as fast as someone with a machine.
Old 28-10-07, 09:32 PM   #18
Blue_SV650S
- Always thake the discs off first!
- Remove the inner valve to allow full deflation
- Prop on blocks of wood/a doorstep and use a spade to break the bead.
- Use fairly liquid or tyre soap to do the lubing on the removal and fitting. (I am not convinced by what chunky said, as I have used fairy liquid for years and never had a tyre spinning problem - including track/race use!! ).
- Leave the inner valve out and use a double barrelled footpump to get the tyre back on the bead. As long as the inner valve is still out you get enough puff, I have actually found forecourt (petrol station) pumps lacking in initial puff, so not sure that is a great solution (you also need to get the wheel there )!!
- Once the tyre has popped on its bead, you can re-insert the inner valve and pump up normally!!
I have popped a tyre on the bead by igniting lighter fluid in the tyre before now (saw it once on top-gear ) but the double barrelled foot pump job is perfectly effective, and you get to keep your eyebrows!!
- Balancing is as described - axle stands (two stools or whatever) and the wheel spindle ...
Once practised, it is easy enough to do, why pay £20 for some yoof to take big chunks out of your rim down ATS when you can do that perfectly well yourself in the comfort of your own home??!?
Old 29-10-07, 09:25 AM   #19
Blue_SV650S
Oh and better add, I don't use washing up liquid neat - I uses a 'solution' ... not as thin as washing up mix, prolly about 1/2 way between washing up and neat ... if people are using neat, that might be why they are getting a spinning problem?!?!
Old 29-10-07, 09:28 AM   #20
the white rabbit
Make a triangle out of wood, will save you a few mins.
when do you change your tyres? hovis Bikes - Talk & Issues 30 09-04-09 10:37 PM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
tyres change advise rlion Tyres 4 21-02-06 03:21 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
