Old 19-06-09, 03:09 PM   #21
Default Re: Tank Spacers?
With a stock SV, there isn't that much difference in flow from a slip on can to the standard one.
And you try any can on the market, it will be so similar as to be not worth a jetting change against any other.
Old 19-06-09, 03:23 PM   #22
SoulKiss
SoulKiss's Avatar
Originally Posted by dyziowg View Post
[derail]
I've got a set of Chewy's raisers somewhere, if anyone wants them, give me a shout.
[/derail]
Shout
Old 19-06-09, 04:22 PM   #23
JPBiker645
Originally Posted by GavinD View Post
. . . if you set it up on a dyno to match with carburation etc
No need for a dyno tune ... the jet kit tells you what jet to use and any problems you run into it shows you how to correct it.
Old 19-06-09, 04:25 PM   #24
JPBiker645
He meant which model is the kwak?
i was just wondering what would work for my bike ... but thats a whole different thread no worries.
Old 19-06-09, 05:52 PM   #25
Easiest is slingshot stuff, but SRAD isnt much harder and better kit.
Re. jet kits and stuff, there are generally no jetting problems just with a slipon can. So if you want to spend £60 on a jet kit knock yourself out...
Old 19-06-09, 08:52 PM   #26
JPBiker645
now that we are completly off topic
Isn't a stock muffler much more restrictive?
Old 19-06-09, 11:08 PM   #27
Not much more than the stock headers.
Old 20-06-09, 02:58 AM   #28
JPBiker645
really? all the baffles and such in side the can is more restrictive than a just a pipe? .....
Old 20-06-09, 05:03 PM   #29
GavinD
well yes - but the backpressure helps midrange torque
to get the bhp i got I had to put in injected cams (its a curvy), then do all the jetting, balancing etc
result 71 BHP and 45 ft/lb torque!!
then I had to do suspension and brakes to match!!
Old 20-06-09, 06:02 PM   #30
speedplay
Originally Posted by JPBiker645 View Post
wouldn't increasing the flow out the exhaust require me to re jet it .... wouldn't it lean it out?
no racing for me, just wanna make the bike at low rpms a little more snappy.
Why dont you just change the rear sprocket?
Top end will be affected slightly but 0-60 will be quicker.
Swap - Chewy`s Tank Spacers xXBADGERXx For Sale - SV's and SV related items 6 10-07-08 04:43 PM
Tank spacers - advice req'd netsurfer SV Talk, Tuning & Tweaking 15 06-01-07 03:58 PM
tank spacers 01 sv650s SV Talk, Tuning & Tweaking 35 01-11-06 02:52 PM
Curvy's+Tank Spacers+Cool/Damp Weather = Ropey Running Dan_SV SV Talk, Tuning & Tweaking 3 19-04-05 03:07 PM
Air supply :: Tank spacers :: Other methods snoopy SV Talk, Tuning & Tweaking 38 07-01-05 06:38 PM
