Old 20-04-10, 10:26 PM   #21
stew
Default Re: Ignition problem.
im going to give it a go tomorrow when i get home from work.
i was just looking at it and the wires comming out of the connector seem very tight and pulled over to the left
thanks for your help
ill keep you all posted on the outcome on the next test.
Old 20-04-10, 10:28 PM   #22
stew
Default Re: how to tell if ecu/cdi is on its way?
the coil is not sparking at all.
think it might be the negative wire from the coil to the cdi.
Old 21-04-10, 09:27 AM   #23
Carefully check the wiring and connectors, the control unit isn't immune from failure - but it's rare. The problem is more likely to be the cabling, connectors or coil itself by a significant margin.
Being as how the control unit is also the most expensive part of the system by quite some degree I'd make absolutely certain of everything else before condemning it.
Old 21-04-10, 09:09 PM   #24
stew
good news
turns out it was the rear ht lead was brakeing up.
i had replaced it but not pushed it on hard enough.
now my baby is working. going to change the front tomorrow.
a big thank you to the members of the org for all the help on this.
THANK YOU
weird ignition problem florida650 SV Talk, Tuning & Tweaking 10 13-08-07 06:22 PM
Help! Help! please, ignition problem cwachang SV Talk, Tuning & Tweaking 1 17-07-06 10:41 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
Please Help! Help! ignition problem cwachang Bikes - Talk & Issues 4 04-05-06 12:16 AM
Help! Help! please, ignition problem cwachang SV Talk, Tuning & Tweaking 6 03-05-06 05:57 PM
