Old 10-08-11, 03:18 PM   #21
Default Re: Balancing wheels on the bike
i can't tell you any scientific explanation as i'm not a guru. but they do work. i have resisted telling people as i knew i would get 'its a load of bull' yada yada.
ok so its not the cheapest way of doing it as it works out to about £2 a wheel but the convenience outweighs. i suppose if i was a tight wad i could re-use them.
i found this on youtube which sorta explains the effect.
http://www.youtube.com/watch?v=eq263...eature=related
Old 10-08-11, 04:33 PM   #22
-Ralph-
That's a car wheel though
That's what I said!
dynamic balancing (2 plane or more) lets you balance any "rocking" imbalance which static balance doesn't show.
I know!
Narrow bike wheels are not as likely to suffer from that type of imbalance, at least not to the extent it causes the rider a problem.
Old 10-08-11, 04:47 PM   #23
-Ralph-
What's to make them collect at the light spot? I can't think of any physical reason.
I'm not going to hurt my brain trying to figure out the physics of it. But if you spun a shaft with two rotor blades on it, and there is enough friction between the blade and the shaft for them to start spinning too, but they are still free to rotate on the shaft.
Then and put an equal weight on one end of each rotor blade, and spun the shaft, would the blades not start to spin on the shaft in equilibrium with the two weights staying opposite each other? It's the least resistance way for them to spin.
Are these balancing weights not just doing the same? They are free to move so they naturally find the place in the wheel and come to rest where they need to move the least?
Balancing spots on new bike tyres. Where to they go in relation to the valve? monkey Bikes - Talk & Issues 9 24-02-08 12:39 AM
Carb balancing by ear? ikb SV Talk, Tuning & Tweaking 16 31-01-08 12:28 PM
Moron sold a bike after I'd agreed to buy the wheels monkey Bikes - Talk & Issues 20 20-10-07 01:23 PM
Think Bike - Do you when you're on 4 wheels? kciN Bikes - Talk & Issues 23 26-04-06 09:44 AM
Bike mods - why not lighter wheels? jump SV Talk, Tuning & Tweaking 23 11-07-05 02:11 PM
