Old 04-01-05, 01:33 PM   #21
BillyC
BillyC's Avatar
Will someone please explain to this man the difference between a motorcycle engine, and a car engine... wet clutches etc, and how this affects the choice of oil...
Old 04-01-05, 01:35 PM   #22
zx6man
most car oils including GTX have friction inhibitors in them. Fine for cars with seperate gearboxs, but can cause major clutch slipping with bikes, as the gearbox uses the same oil. Dry clutches obviously don't (like ducatis). Just use a decent semi-synth bike oil.
Old 04-01-05, 01:35 PM   #23
snoopy
Oh dear Economising gets me into trouble yet again...
Old 04-01-05, 01:37 PM   #24
BillyC
BillyC's Avatar
Now will someone explain the reason for the oil filter?
Old 04-01-05, 01:37 PM   #25
Itching 2 go
Originally Posted by andrewcharnley
Itching 2 go >> no smells from the exhaust. It's running perrrfect.
this is good it meand the air box probably hasnt filled with oil yet and isnt going directly into your engine. i have seen it b4 when comeone over filled their oil level and when they stopped and put the bike on sidestand the left cylinder filled with oil and locked the motor. be carefull not to do this it can be quite expensive! also use a bike grade oil as generally bikes rev harder than cars so the oil is designed to take trhis into consideration not to mention the anti friction agents<eek>
Old 04-01-05, 01:39 PM   #26
zx6man
Castrol GP 4 Stroke Oil 10W40 4 Litre £19.99
Old 04-01-05, 01:40 PM   #27
snoopy
Hey, it still works, sorta..
Old 04-01-05, 01:42 PM   #28
coombest
It still works!!?? What do you mean!?
Of course it still works - you've just changed it for a new one when you filled with oil, right!!??
Old 04-01-05, 01:44 PM   #29
Iansv
I really can't see anyone ever buying your bike off you from here Andrew
Old 04-01-05, 01:45 PM   #30
snoopy
I think I might be stuck
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
