Old 10-09-05, 07:49 PM   #21
Bikeageboy, it's possible it's not getting enough juice if you've wired it into the stock loom- I found if I tried to connect the FIAMMs I use direct instead of replayed, they made a sort of wet fart noise
Old 10-09-05, 11:53 PM   #22
Warren
i dunno- alot of people on the CBR website say that its fine with the standard loom.
Old 11-09-05, 04:14 PM   #23
|They'd know more about it then me Does the CBR have a good stock horn then?
Old 11-09-05, 04:24 PM   #24
argatxa
Originally Posted by SVeeedy Gonzales
Bah! I tried to fit the magnum this morning - where's it meant to go!? There's no way it can fit in the gap that the original horn goes, behind the radiator! Plus the connectors don't match and will need cutting or replacing... poo! I'm thinking of attaching the magnum to the caphead screw on the frame on the left hand side and leaving the old horn there and fiddling witht he connectors, but then it'll look like a dogs dinner.
Stupid Stebel!
mmm... same problem!!! It arrived two days ago, but I didn't have time until this morning, I saw the gap, looked to the siebel, looked again to the gap... mmmmm.... bu***r!!! does not fit!!!
Plus I have the full fairing.... I'm going to have to unscrew all the pannels, try different places and screw them back!! ARg!!!
That screw in the frame that holds all the wiring looks as a good candidate.... maybe next weekend... I am at work now.
Old 11-09-05, 11:25 PM   #25
Warren
dunno mate - all i know is that its miles better than my suzi GS125's horn
Old 12-09-05, 08:59 AM   #26
beefcake
The Stebel Magnum can be located inside the righthand fairing. You can do it without removing any of the fairing panels. When you look at where the radiator cap is, you can see metal fairing support framework with holes drilled along it. You can use one of the holes to attach the fixing plates the magnum comes with.
Process should be:
You will need to attach an additional bit of wire to the horn as the standard horn connectors will not reach. Attach the two metal plates to the back of the Magnum. Situate the horn inside the right hand side of the fairing using a small nut and bolt. Do it up hand tight only. Move handlebars left and right to ensure the magnum clears the steering damper. Then tighten horn fixing plate to the fairing framework.
You can then run the wires back to the original connector (cable tying it to the fairing framework, and use crimped spaded lugs to push into the original connector. Stick some insulation tape around the join, and the jobs done.
You will find that the original connector will pass over the top of the rad, and by using crimped spaded lugs, you can just disconnect the magnum and re-install the original horn as the original connectors will still be there.
PS Helps if you have small hands!
Old 12-09-05, 11:09 AM   #27
BURNER
On a curvey model it'll go right where the original was. The connectors just need seperating and will clip right on.
On a pointy I dunno, I don't have one of those...
Old 12-09-05, 11:30 AM   #28
beefcake
Pointy as per my post above
Old 12-09-05, 11:32 AM   #29
argatxa
Mr Beefcake...
I'll give a go one of this days, if I manage to get out of the office early... or just get out!!!
Old 12-09-05, 12:30 PM   #30
SVeeedy Gonzales
Originally Posted by argatxa
Mr Beefcake...
Ditto! \/
Ive Got the Horn Blue Flame SV Talk, Tuning & Tweaking 33 27-05-08 04:01 PM
Horn ljharmitt SV Talk, Tuning & Tweaking 5 26-04-08 10:18 AM
Where`s My Horn??? Speedy Claire SV Talk, Tuning & Tweaking 33 21-01-08 12:18 AM
Use of horn Blue_SV650S Bikes - Talk & Issues 31 13-12-07 10:35 PM
Get the horn northwind SV Talk, Tuning & Tweaking 44 02-03-05 12:22 AM
