#21 |
How much is it overfilled by? A friend ofmine lost his car engine because of overfilling - but that was by a serious amount. (3+ liters)
As for the only half the window I'd check against the max/min markers on the engine next to the glass. If it's not to the max then complain agian loudly. Stu |
#22 |
noufy, overfilled mine once (easily done) but removed excess oil straight away by gently unscrewing oil filter..as previuosly stated.. so level dropped in viewing glass. too much oil will cause internal problems mate.
#23 | ||
#24 |
If you're worried about checking it, here's some tricks to make it safer... Bungee or otherwise tie the tip of the siedstand to something solid on the frame- crash bugs are good. Stops it popping up. Put the bike in gear. You can also put something under the sidestand to bring it closer to horizontal to reduce the amount of muscle involved, if you want- but make sure it's big enough that the stand'll definately land back on it.
Now, Go around to the right hand side, crouch or kneel down beside the bike so you can see the glass, and pull it towards you- I use the bars, but you can use anything really. it's all about balance, not strength, but unless you're really clumsy the bike won't fall on you- it takes a while to go past the balance point, and it'll be no problem at all to keep it upright even if it does, as long as you don't let it fall too far. If it falls away from you, the stand's fixed in place so it won't go far. The bike will just about balance when it's in the right position... You don't need to be too precise, but I literally have it at the point where I can balance it with one finger. This would be a less good idea with a Rocket 3 ![]() When you're done, lower it back onto the stand gently- you don't need to push it back, just let it slowly overbalance away from you and support the weight as it goes back down.
#25 |
phew its ok, i checked and theres plenty oil in it.
i found I can lean the bike against the wall using the left bar end and it stays nice and steady ![]() |
#26 |
....or you could do that
#27 |
Drain it and start again then, duh.
#28 |
Drained it using the Brakes bleeing kit, was easier to do in the cold early morning, Had about 450ml extra in there. She sounds OK
Engine Breaking? Hopefully not. Engine braking - is that OK? | butterick99 | SV Talk, Tuning & Tweaking | 14 | 12-09-09 10:31 PM |
Overfilled coolant - possible problems? | arcdef | SV Talk, Tuning & Tweaking | 16 | 17-12-08 02:48 PM |
help please:- overfilled the oil | custard | SV Talk, Tuning & Tweaking | 3 | 13-07-08 11:41 AM |
Engine braking... any hazzards engine wise? | John 675 | SV Talk, Tuning & Tweaking | 21 | 28-03-08 07:20 PM |
Engine out or not ? | Banus | SV Talk, Tuning & Tweaking | 18 | 05-01-06 11:22 AM |
