Old 12-04-07, 09:37 AM   #21
Blue_SV650S
Default Re: Ignition Retarder
Originally Posted by Born again View Post
Yes that is looking at the mating face, ie looking at the end you would put the blade in to release the wire. Numbered left to right........
TA
Old 12-04-07, 10:48 AM   #22
hovis
Ehy You Refitting Them Blue?
Old 12-04-07, 10:52 AM   #23
Blue_SV650S
Yes, its only to make sure my bike falls in-line with minitwin regulations on my trackbike/s if/when I race it, that's all ... I intend to leave it done on my road bike!! its a bit of a pointless reg anyway ... I mean how often does a race-bike see 3-4k??? I'd wager only when it is on the stand warming up!! .. anyway, thems the rules, so thems the rules and I will abide
On my commute on my road bike, it sees 3-4k in 2nd and 3rd plenty
Old 12-04-07, 12:03 PM   #24
What I meant was, it doesn't cost you power, it just means you need more revs to get the same power. Obviously that's still not good but a lot of people think they're going to get power on top, so I was getting at that. Or trying to anyway
Old 12-04-07, 12:28 PM   #25
danf1234
I bought one of these off e-bay which I am led to believe does the same job. I haven't fitted it yet though.
http://cgi.ebay.co.uk/G-PACK-for-SV6...QQcmdZViewItem
Old 12-04-07, 01:44 PM   #26
hovis
i cant do it
how do you relese the wires?
Old 12-04-07, 03:16 PM   #27
Blue_SV650S
I know YOU know what you are on about, I was pointing out that it didn't quite read as it might!!
Old 12-04-07, 03:26 PM   #28
i cant do it
You can just cut them... And insulate the ends, obviously. I cut mine at the time, just recently I removed them from the connector just by pulling with pliars. Hulk smash. But it works
Old 12-04-07, 03:47 PM   #29
hovis
did'nt really want to cut the wires, if they need to be connected back up thers not a lot of wire to play with
anywho........... going to the local meet tonight so might get sombody to give it a go?
its just im not sure whre i should be putting the screwdriver
Old 12-04-07, 04:01 PM   #30
Blue_SV650S
You will need a small screwdriver, like a watchmakers one ... or one that you repair glasses with ... as someone else said, you are trying to lift a little retaining plastic bit ... so take the plug off the CDI and jam the screwdriver in along the top surface of the relevant connector .... if you push it home it will lift the flap, the wire can then be removed with a gentle tug
ignition retarder BIKER-DENE SV Talk, Tuning & Tweaking 29 08-03-07 12:17 AM
2nd & 3rd gear ignition retarder removal localhost SV Talk, Tuning & Tweaking 1 19-04-06 05:38 PM
Disabling ignition retarder - worth it? red5 SV Talk, Tuning & Tweaking 9 29-03-05 04:02 PM
Ignition retarder peterjohnwood SV Talk, Tuning & Tweaking 1 11-03-05 10:31 AM
Ignition retarder Dicky Ticker SV Talk, Tuning & Tweaking 1 09-03-05 07:35 PM
