Old 16-05-07, 01:39 PM   #21
embee
embee's Avatar
Default Re: Can't use my SV in the wet.
As well as the fender extenda and silicone grease, I made a small aluminium shield which fixes on the two fan bolts and effectively closes off the gap between the rad and cyliunder head, plus there's a small extension tab going up behind the rad in front of the plug.
Belt, braces and sticky tape, me!
Old 24-05-07, 09:46 AM   #22
sami_g
Smile Re: Can't use my SV in the wet.
Thanks for all the help guys and girls, seem to have sorted the prob for now, but i will find out when it rains
Old 24-05-07, 10:20 AM   #23
Viney
Move down south, it doesnt rain as much as up in Scottyland
HTH
Old 28-05-08, 11:33 AM   #24
Al_Sweetman
As an aside, does one have to be careful to avoid cutting down airflow to the cylinder though?
Old 28-05-08, 11:38 AM   #25
DanAbnormal
Welcome to the marvellous design of the SV. Copper grease my sort it.
Old 28-05-08, 12:08 PM   #26
embee
embee's Avatar
No, as long as you don't blank off significant areas of the rad. The pic seems to have disappeared, but the shield I made just closed the gap between the rad and cylinder head along the bottom to prevent water being splashed up behind the rad. It also has a small tab bent up to shield the plug cap itself from water going through the rad but I'm not sure whether that's essential or particularly effective. It all works though.
Old 28-05-08, 12:43 PM   #27
SoulKiss
SoulKiss's Avatar
Welcome to the land of Zombie Threads.
This one had been at rest for just over a year
Old 28-05-08, 05:44 PM   #28
Al_Sweetman
BUt good threads never die!
Old 28-05-08, 11:24 PM   #29
injury_ian
The same fault happens to all the SV650s. Not to Raptors though, since Cagiva redesigned the boot.
Can we not fit these to the Sv then, being the same lump'n all?
*hurries to find cagiva dealer before they all run out...
Old 28-05-08, 11:45 PM   #30
Never happy you, if someone had started a new thread you'd say "Use the search"
