Old 20-06-09, 08:47 PM   #31
JPBiker645
Default Re: Tank Spacers?
Why dont you just change the rear sprocket?
Top end will be affected slightly but 0-60 will be quicker.
I want to be able to hear it... I know thats lame but thats what I want..
Old 20-06-09, 08:55 PM   #32
speedplay
Then put a different sprocket on and bung some playing cards in the front wheel..
Old 20-06-09, 08:59 PM   #33
JPBiker645
nice but I allready have the can and jet kit wasn't too bad (60$)
How much are sprockets?
Old 22-06-09, 09:09 AM   #34
Jets are about £2.50 IIRC. See why I didn't buy a jet kit...
Old 22-06-09, 10:58 AM   #35
boo86
Originally Posted by GavinD View Post
well yes - but the backpressure helps midrange torque
to get the bhp i got I had to put in injected cams (its a curvy), then do all the jetting, balancing etc
result 71 BHP and 45 ft/lb torque!!
then I had to do suspension and brakes to match!!
I've got 72 with curvy cams. Only breathing mods and a slight ignition advance. It's cold up North though, that always helps.
Old 22-06-09, 11:07 AM   #36
GavinD
I dyno'd on a hot day - been meaning to redo it on a colder day to see what the difference is!
Old 22-06-09, 12:41 PM   #37
boo86
Aye, it makes a big difference. A normally asperated 4 stroke piston engine loses 1% of power for every 7C rise in inlet temperature. That's the reason I never run a burn crank case breather system. My sv uses a condensing system where the hot oily gas condenses then flows back to the crank case. It vents to atmosphere to prevent pressurisation.
But if your engine / crank case is breathing oily gas at 100C + into the air box your on a fast train to power loss.
It was about 15C when I dynoed mine. But it wasn't too humid, only about 30% humidity. As this also makes a big difference. Basicaly the more water in the atmos the less room there is for o2.
Old 22-06-09, 01:16 PM   #38
flymo
flymo's Avatar
Consisting of what? Is this just a set of filters on the crankcase breather hoses or something a little more fancy with a catch tank etc?
Old 22-06-09, 03:40 PM   #39
boo86
It's the standard catch tank but where it normally breaths into the airbox it's blanked off and it has a small breathing hole drilled in facing the airbox. As it's filled with baffle it condenses and runs back down. I've never had 1 drop leak out of it.
It works great, no hot air into the airbox and the crank case can still breath no probs. No leaks, it's all good.
Old 22-06-09, 03:47 PM   #40
GavinD
Can I be a pain and ask for some pictures of this?
Swap - Chewy`s Tank Spacers xXBADGERXx For Sale - SV's and SV related items 6 10-07-08 04:43 PM
Tank spacers - advice req'd netsurfer SV Talk, Tuning & Tweaking 15 06-01-07 03:58 PM
tank spacers 01 sv650s SV Talk, Tuning & Tweaking 35 01-11-06 02:52 PM
Curvy's+Tank Spacers+Cool/Damp Weather = Ropey Running Dan_SV SV Talk, Tuning & Tweaking 3 19-04-05 03:07 PM
Air supply :: Tank spacers :: Other methods snoopy SV Talk, Tuning & Tweaking 38 07-01-05 06:38 PM
