Old 08-03-12, 04:59 PM   #31
paulmsv650s
Default Re: 115 miles 'til fuel light.
i just use this link easy as http://www.torquecars.com/tools/uk-mpg-calculator.php
Old 09-03-12, 10:07 PM   #32
BoostFairy
Is this bad? I thought 130 was good?? With 15 litres that works out at around 40 MPG, my light flashes routinely at 110-120 miles and goes solid at 130-135, I recently got 135 on 14 litres which is about 44mpg....
I thought 40 to the gallon was pretty good going?
Old 09-03-12, 10:50 PM   #33
AZZ3R
I got 127 - Light for £15, that was with commuting to work & the odd short blast on the M/way.
Shell Reg Unleaded.
Old 09-03-12, 11:18 PM   #34
Bluefish
Originally Posted by sixstring View Post
One gallon is equal to 3.785412 liters.
I knew it, thank you google
wrong. Ah, you mean yank so definately wrong :0)
Old 09-03-12, 11:23 PM   #35
Bluefish
Listen guys when it's empty you put more in, it's not rocket science
Old 10-03-12, 01:52 AM   #36
Mikey10
Quick question about the fuel.
My fuel light has never flashed it starts solid then switches off around 3 -5 mins later then back on and reapeats is this what you guys would call flashing as its never been a faster flash and i've never had a solid fuel light for any more then about 5 minutes. i genrally plan a stop the mintue i see it as it seems inconsistent so i don't take the risk of pushing my luck to find out. should i maybe get someone to check it out as i don't want to be in one of those situations of pushing it home as i live on a hill.
Its not major important to fix but is it worth a look at in case its faulty and the fuel is lower than i think.
i do notic a very small change in the engine note and delvirance of the power which i guess is normal on lower fuel.
Not much mor ei can think of that.
This is my first bike as im only 19 so any guidance would be great.
thanks
Old 10-03-12, 09:49 AM   #37
HoL
I believe the curvy & pointy are opposite ways round so the curvy flashes to begin with then goes solid when its really low & the pointy is solid to begin with & flashes at panic stations. I'd say you've never got low enough to make it flash. I wouldn't worry about the light going off after a bit, mines the same. It'll be the fuel splashing around so it thinks its low then its thinks its not if you know what I mean.
Old 10-03-12, 09:52 AM   #38
-Ralph-
My pointy flashed first
Old 10-03-12, 10:04 AM   #39
HoL
Oh, then my belief may be wrong. I could have sworn I'd read that on here?
Old 10-03-12, 05:19 PM   #40
takracing
Just got back from a 2up ride around the norfolk coast, completing over 160 miles,
Filled up when left, light started flashing at 148 miles, filled up at 158 miles and light still flashing, tank took 13.14ltrs
So from my calculations an average of 19.35 km / ltr or 54.67 mpg
Bike is 2000 curvy, im 210lbs without leathers and pillion is 168lbs
Some quick riding and very twisty b roads so a good mix, no serious hills tho.
Jim
Pointy Fuel Light- Not another how many miles thread Vergey SV Talk, Tuning & Tweaking 3 06-08-11 01:01 PM
OMG! 143 miles until fuel light 53mpg! I'm_a_Newbie SV Talk, Tuning & Tweaking 22 26-06-08 12:06 PM
125 Miles Until Fuel Light, Yippee I'm_a_Newbie SV Talk, Tuning & Tweaking 13 14-05-08 12:03 PM
fuel light flashing how many miles till it runs out jans1971 Bikes - Talk & Issues 29 10-10-07 09:47 PM
180 miles and no fuel light... Tiger 55 Bikes - Talk & Issues 21 09-07-07 06:25 PM
