Old 22-06-09, 03:53 PM   #41
boo86
Default Re: Tank Spacers?
Originally Posted by GavinD View Post
Can I be a pain and ask for some pictures of this?
I'll try get some next time I'm home. It's pretty intuative. You just block the 2 x holes (or is it 1 ? can't remember) running into the air box. I used normal bathroom silicon. Then you've made your self a sealed colector box which is obviously no good so I drilled a 5mm hole in the standard collector box. Do it right at the top so the oil will condense and fall back down. My collector box is filled with anti baffle foam but I don't know if that's stock or not. The collector box just screws off the air box with 2 posi-drive screws.
Bob's your dad's brother etc. You can't go wrong.
Old 22-06-09, 04:06 PM   #42
flymo
flymo's Avatar
Originally Posted by boo86 View Post
It's the standard catch tank but where it normally breaths into the airbox it's blanked off and it has a small breathing hole drilled in facing the airbox. As it's filled with baffle it condenses and runs back down. I've never had 1 drop leak out of it.
It works great, no hot air into the airbox and the crank case can still breath no probs. No leaks, it's all good.
Dont think the pointy has a catch tank, it breathes straight into section of the airbox with a chunk of foam gauze in it.
Old 22-06-09, 09:26 PM   #43
GavinD
I think I need to see it to understand it - the collector looks like a mini air box in the left hand side under the air box right?
Its ringing some bells from my old mini twin I think,
If photo's are no a pain, as and when!
Swap - Chewy`s Tank Spacers xXBADGERXx For Sale - SV's and SV related items 6 10-07-08 04:43 PM
Tank spacers - advice req'd netsurfer SV Talk, Tuning & Tweaking 15 06-01-07 03:58 PM
tank spacers 01 sv650s SV Talk, Tuning & Tweaking 35 01-11-06 02:52 PM
Curvy's+Tank Spacers+Cool/Damp Weather = Ropey Running Dan_SV SV Talk, Tuning & Tweaking 3 19-04-05 03:07 PM
Air supply :: Tank spacers :: Other methods snoopy SV Talk, Tuning & Tweaking 38 07-01-05 06:38 PM
