Old 11-09-09, 04:08 PM   #41
admin
John T
admin's Avatar
Default Re: Scottoiler v Lube
I use cheap engine oil. Works fine
Old 11-09-09, 04:43 PM   #42
Alpinestarhero
Even old engine oil will work fine. Dont forget to viually inspect the chain once a week, and clean it sometimes. Grit may still accumulate on that plastic / rubber runner thing on the swingarm, stuff like that
Old 11-09-09, 08:45 PM   #43
punyXpress
punyXpress's Avatar
Any hints or tips .... particually on getting it filled cleanly ??[/QUOTE]
Got a few small pipettes from work & cut off the end of one to put on the end of the filler tube from the bottle.
It's half the thickness of the original filler - goes in further & lets air out without globs of oil.
Now: Street Triple R
Old 11-09-09, 08:51 PM   #44
admin
John T
admin's Avatar
I use a syringe left over from a printer cartridge refilling kit.
Old 11-09-09, 09:12 PM   #45
fastdruid
fastdruid's Avatar
What's wrong with the bottle and tube? Designed for filling it.
Worth buying just one bottle if you don't have one.
Druid
Old 12-09-09, 07:17 AM   #46
peddler
Does anyone know if the universal scottoiler fits an sv(06).
Just bought an sv and had one on my last bike, definatley fit another.
The scot oiler home page just lists a new 'v' version which is £83.
Old 12-09-09, 09:52 AM   #47
LK-SV
Its a very basic bit of kit - it'll be fine!!
I'm having a bit of bother getting the straw bit at the end to stay where it needs to be - very small surface area for it to sit without it on the chain, or in the gaps in the sprocket - any ideas??
Old 12-09-09, 10:04 AM   #48
fastdruid
fastdruid's Avatar
Personally there I'd mount off the bobbin mount, you have quite an amount of dangle there for it to move about.
You can see how I did it on the VFR on the previous page, it was pretty much the same setup I used on the SV.
Druid
Old 12-09-09, 05:24 PM   #49
LK-SV
Ah - that's better!!
Looking good!!
Now - couple more things....
Doesn't the nib wear down quickly?? And will the chain clean itself now, or do I need to clean it to give it a headstart....
Chuffed !!
Old 12-09-09, 05:27 PM   #50
fizzwheel
fizzwheel's Avatar
No it doesnt
No the chain wont clean itself, if you turn the flow rate up high on the oiler, the oil will wash the chain and clean it to a certain extent, but its an Scottoiler not a Scottchaincleaner
Like has been said, the oiler isnt a substitute for regular chain maintenance including cleaning...
If you want to clean your chain, get some parafin and an old paint brush or I use a toothbrush and give it a good going over with that instead.
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
which lube? krhall Bikes - Talk & Issues 39 02-10-08 07:00 AM
Do I need to lube up?? DoubleD SV Talk, Tuning & Tweaking 2 12-06-08 10:52 AM
Wax or Lube?? Morpheus Bikes - Talk & Issues 26 18-03-05 06:55 PM
What lube do you use? chutz SV Talk, Tuning & Tweaking 26 09-03-04 01:37 PM
