Old 03-08-10, 08:19 PM   #41
Default Re: brake overhaul
You probably need to get some in around the seals, I bet you have bit of corrosion in there.
Old 03-08-10, 08:32 PM   #42
xXBADGERXx
Best way I have found to remove a seized piston is to zip up a cable tie around it and then use some grips to rotate it out of the Caliper , the outside of the piston is protected by the soft plastic of the cable tie and inside it doesn`t matter does it . Hope this may help a bit . WeMoto are handy for complete seal kits by the way .
Old 03-08-10, 08:34 PM   #43
I'm gonna try that one badger!
+1 for wemoto for brake seals
Old 03-08-10, 08:37 PM   #44
I would advise strongly to use the bikes built in, high pressure hydraulic brake piston removal tool.
Old 03-08-10, 08:40 PM   #45
Thats 10 times easier! Just thinking for the loose rear one i'm stripping down tomorrow
Old 03-08-10, 09:18 PM   #46
thefallenangel
do i need new seals or can i get away with re-using?
And i've got clamps ready to hold the piston in while pumping out.
Old 03-08-10, 09:19 PM   #47
99% of time you can reuse them with no problem
Old 03-08-10, 09:21 PM   #48
thefallenangel
Brilliant. Will start tomorrow.
Brake overhaul, what bits? 5hort5 SV Talk, Tuning & Tweaking 18 11-12-09 09:44 AM
Brake Overhaul - picture heavy Al_Sweetman SV Talk, Tuning & Tweaking 37 27-02-09 10:44 AM
Brake Overhaul Crash_Artist SV Talk, Tuning & Tweaking 3 18-02-09 07:44 PM
Front brake overhaul - how much? DarrenChay SV Talk, Tuning & Tweaking 7 03-01-09 09:12 PM
Brake overhaul Fuzz SV Talk, Tuning & Tweaking 4 13-03-06 11:51 AM
