Old 01-01-11, 10:26 PM   #51
hongman
Default Re: Fuel prices
Yeh-what he said man
point the sign towards my name
Old 01-01-11, 10:27 PM   #52
i drove past a few petrol stations this evening and realised my beemer is now worth about a fiver!!
Old 02-01-11, 08:12 AM   #53
Berlin
Any diesel engine can run on Veg oil. It just might not run on pure veg oil. If its only got one glow plug it might be a bugger to start on cold mornings on pure oil.
And modern common rail or otherwise diesel will run (better than usual) on a 50/50 mix of Veg oil and diesel. If you have a Bosche fuel pump, no adjustments required. If you have a Lucas pump, the grub screw in the centre of the pump needs to be turned in by 1/4 turn to increase flow.
And if you shell out a preheater (£25 quid), you can run higher ratios of Oil. The preheater just heats the oil making it less viscous meaning it injects better.
Veg oil isn't "bio diesel" which does affect O rings over the long term due to alcohol being present in it. Veg oil does no damage at all. You do need to change the fuel filter every 3-4000 miles. (£4.50!)
I've now been running my van on Veg oil for 18 months (most of that time at 90%+ veg oil. Its happiest at about 75% oil/ 25% diesel. and sees higher economy, more power, smoother running, better throttle response and a higher cruising speed.
Its currently under £18 for 20 litres at Costco but limited to 200 litres per customer per trip. I just pick up 6 tubs each time I go. Two go straight in the tank and 4 sit in the back for topping up as required.
in 18 months, I've *saved* enough on fuel to mean my van was effectively free
C
Old 02-01-11, 10:49 AM   #54
thefallenangel
my C1 is going in for it's LPG conversion, and it's gonna take 1690 litres to pay back which will work out at 15,000 miles providing the government don't stick anymore tax on fuel come budget time.
And if i was to run a diesel on 50/50 it would be a good idea too.
Old 02-01-11, 04:23 PM   #55
Originally Posted by steveg View Post
the early sprint plastic tank is 21 L
With the price of unleaded locally approx £1.25 per litre
21 L * £1.25 = £26.25
Normally fuel up 180 - 200 miles and put 18 - 20 l in
Cheers Steve
I filled my sprint up today after my gauge said I had 18 miles left, it was running on fumes tbh as the light had been on a while, even at £1.25 a litre I still couldnt get more than £19.60 and that was brimmed.
Your tank must be way bigger than mine ?
Old 02-01-11, 04:30 PM   #56
orose
One thing I found when I had a sprint demo bike was that the gauge lies (a lot) - it varied from saying 270ml to go when full to 40 with a single bar remaining. I think it uses the consumption figures and current level to guess, so RPM matters a bit.
Old 02-01-11, 04:41 PM   #57
It was ticking over tbh, plus it had done 175 miles from last fill up so was getting close by that method also.
Old 02-01-11, 04:50 PM   #58
Lozzo
I know I'm being overly generous here, but I can't stop helping a mate in his hour of need. I'll give you my Beemer and a tenner in exchange for yours cos I'm a kindly soul - I'll even leave the new tyres on.
Old 02-01-11, 07:23 PM   #59
-Ralph-
Stick a gerry can in your top box, ride 'til it runs dry, stick the 5 litres in, and at the next petrol station see if brimming it will let you get another 15 litres in.
Old 02-01-11, 08:18 PM   #60
tactcom7
Saw £1.35 a litre about 4 weeks ago nr Ipswich...
Fuel Prices - again plowsie Idle Banter 90 16-06-08 01:04 PM
petiot fuel prices... kat_s1 Idle Banter 43 12-06-08 01:31 PM
Fuel Prices plowsie Idle Banter 50 06-08-07 08:11 AM
Fuel tank prices clacs2 SV Talk, Tuning & Tweaking 13 16-07-07 04:00 PM
fuel prices Gnan Idle Banter 39 21-04-06 09:13 AM
