Old 05-01-08, 09:44 AM   #1
SV-net
Default Will a 1000 Lump gor Straight into my 650 ?
I can get one from a front ended 1000 and wondered if I could just swap it for my 650?
Comments and suggestions please.
Happy new year.
Old 05-01-08, 09:48 AM   #2
MiniMatt
Default Re: Will a 1000 Lump gor Straight into my 650 ?
To the best of my knowledge, no is the simple answer. I'm sure someone will explain better, but the SV1000 and the 650 are very different bikes, they just look like each other is all.
Old 05-01-08, 09:55 AM   #3
Bear
Yep, I'm pretty sure it's not going to work. While the 650 and thou look almost identical they share almost no common parts. Sorry dude
Old 05-01-08, 10:03 AM   #4
SV-net
Hmm maybe then the other ?? is will my front end fit the 1000? Forks are bent on it.
Thanks for your comments.
Old 05-01-08, 10:14 AM   #5
Alpinestarhero
Again, the front end from a 650 is designed to cope with differant demands from the 1000; I would think that the 1000 front end is firmer, and thicker forks, to cope with the extra weight of the thou
A tl1000s front end might go on...
Matt
Old 05-01-08, 10:31 AM   #6
MiniMatt
Yeah, especially given that the 650s forks are arguably it's weak spot (well, if not weak, then just the bit where the budget shows most), I'd not want to stick them on a heavier more powerful bike. People have been known to stick (with a bit of hammering involved) gixxer front ends on 650s mind.
Old 05-01-08, 10:32 AM   #7
mattSV
mattSV's Avatar
SV1000 lump will NOT fit a 650 without major frame mods.
The stock SV650 forks are generally considered the weakest part of the 650, so even if they did fit (pretty sure they wouldn't) I would definitely not want to put them on a sv1000.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 05-01-08, 11:55 AM   #8
Ratty
Ratty's Avatar
There are both standard and GSXR fronts ends available on ebay for the SV 1000 at the moment.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 05-01-08, 12:05 PM   #9
Happy new year.
I've heard that the 650 can go into the thou with some more spacers, but not tother way round. (possibly very dodgy info that! 3rd hand from my mates cousins dogs auntie....)
Putting GSXR forks onto the SV thou is how I'd go about it, not sure what bearings you'd need, if you're lucky it'd be a straight swap like for the pointy. (if you even needed the different yokes?)
Old 05-01-08, 02:20 PM   #10
Ratty
Ratty's Avatar
Here are the links. Taken off a tuned SV1000 that the guy is splitting.
http://cgi.ebay.co.uk/GSXR-1000-K1-2-front-forks-Nice-upgrade-for-SV-1000_W0QQitemZ160194221963QQihZ006QQcategoryZ10534 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/GSXR-1000-K1-2-Top-Bottom-Yokes-Nice-upgrade-SV-1000_W0QQitemZ160194225258QQihZ006QQcategoryZ10534 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
And here is you ready tuned engine.
http://cgi.ebay.co.uk/Suzuki-SV-1000-JHS-Yoshimura-Kitted-Race-Engine_W0QQitemZ160194233800QQihZ006QQcategoryZ105 34QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ratty
SV650 Lump in a KR1S Frame (Courtesy of JanBros) mattSV SV Talk, Tuning & Tweaking 69 22-05-13 07:35 PM
new straight bars on my sv naked jans1971 Bikes - Talk & Issues 13 27-09-08 03:21 AM
straight handlebars of a naked sv jans1971 Bikes - Talk & Issues 3 22-08-08 09:24 PM
Which rear shocks bolt straight in ? ELR4ever SV Talk, Tuning & Tweaking 6 08-03-08 10:23 AM
So let me get this straight... doub1etap Idle Banter 24 18-09-06 10:57 AM
