Is gap filling polyurethane foam waterproof?
Need to fill a >1" gap at end of bath. Gap nicely covered with moasic tiles but joint had cracked with movement or silicon seal had gone with time and water had saturated ply underneath I had previously filled gap with and tiled over, dragging clour out of wood and up through grout (believe it or not!). So I'm planning on filling gap with foam and topping over that with the moasic. If joint fails again am I asking for trouble? I think not as although aero like I think the foam is impervious. Correctamundo? [Its a damp area but not submerged, btw] |
Hey your the clever one. Work it out yourself.
I've used it to block holes from the outside and it seems fine. However, that is not to say I know that it is waterproof, just that it hasn't let the weather in yet. |
Where the hell am I?
not entirely waterproof stuff Doc, as it expnds it leaves ltlle gaps here n there.
i'd use that first, then a shi* loads of clear silicone sealant on top which is then smoothed over and flat with a wet blade edge of something suitable like a butter knife or spatula and then allow to dry. they fill any remaining gaps with more silicon sealant. I tend to go over what i'm filling with the sealant and then trim off excess with a very sharp blade myself. HTH
. "Computers are great! Not for communicating tho. They have one fundamental flaw ... they don't have eyebrows." AlpineCarStereo: you win ....... eeerrr ..... ummm ..... my undying support of you, the greatest Mod this forum has ever known. My Leige. davepreston: ![]() |
Ta.
![]() Vile stuff though. |
Whatever you do, DO NOT get it on your hands. I was using it at work and the gun buggered up and started spraying the stuff everywhere. Took me days to get it off my hands (loosing some skin in the process). It is still stuck to my work trousers to this day, and thats after loads of times in the washing machine.
No comment on the foam, but I will only use Dow Corning silicone sealants in bathrooms/kitchens now. They are so much better to apply and reliable in use than anything else I've used. Sanitary grade 785 is what you want, 786 food safe stuff would be OK if necessary.
Plumbers' merchants often stock it (Plumb Centre etc).
yeh clothes also do not like this stuff !!!
HTH |
My clothes loved it, in fact they're kinda attached now!!
#9 |
#10 |
Get a proffesional in.
See you in abit |
Stupid tank foam | johnnyrod | SV Talk, Tuning & Tweaking | 15 | 20-11-07 08:45 PM |
Seat foam/cover | Flamin_Squirrel | Bikes - Talk & Issues | 1 | 14-10-07 05:20 PM |
removing airbox foam | hovis | SV Talk, Tuning & Tweaking | 27 | 08-01-07 09:36 PM |
foam under tank | 01 sv650s | SV Talk, Tuning & Tweaking | 9 | 02-11-06 08:22 PM |
inserted new foam in my seat myself.! | Quiff Wichard | Photos | 27 | 14-05-06 09:25 PM |
