Old 21-01-08, 10:43 PM   #1
ELR4ever
Default Tachometer died, where is the sensor?
Just restored my '99 to stock carb set up, from the desnorkeled/jetted/shimmed. Anyway, slapped it all together and the tach is not functioning. Everything else running fine. I assume I disconnected a wire or bumped a sensor connection while taking the carbs out, anyone have any input? Was working t!ts up 'til just now. Cheers -D#
Oh yeah, also put in new plugs at the same time, the dual sparky type. Don't tell me I mashed the front plug connector? They related?
Old 21-01-08, 10:48 PM   #2
ELR4ever
Default Re: Tachometer died, where is the sensor?
Yorkie, Northwind where are you, I know you got answers!
Old 21-01-08, 11:02 PM   #3
There's no sensor as such - the tach is driven from the ignition system, check you've not disturbed any of the wiring.
At the tach there are three connections - hot and cold, and one out of the ignition system.
Old 22-01-08, 07:06 AM   #4
ELR4ever
Cheers Sid, will be in there tonight troubleshooting. -D
Old 22-01-08, 07:34 AM   #5
tranx
As far as I can tell the tach will use the positive and negative feed of the clocks along with a 3rd line from the first ignition coil to determine the firing rate. I'm currently trying to re-wire a stock tacho back into the race loom on my bike.
On a side note does anybody have experience of managing to cut down the standard clocks? The interior has both the tacho and speedo and idiot lighgts on a single large circuit board. Ideally I'd like to drop all but the tacho.
Pointy died on me. Faisal SV Talk, Tuning & Tweaking 73 10-12-08 08:37 AM
Tachometer question from a noob lestat210 SV Talk, Tuning & Tweaking 4 22-01-08 10:58 AM
It died. Part 2 yorkie_chris SV Talk, Tuning & Tweaking 8 15-10-07 04:26 PM
It died on me... yorkie_chris SV Talk, Tuning & Tweaking 7 12-10-07 11:10 AM
Tachometer problem Roorkee SV Talk, Tuning & Tweaking 0 25-07-07 06:20 AM
